__________________________________________________ _____
My 64 Impala Build:
http://www.layitlow.com/forums/index.php?s...&#entry19719878
Feed back:
http://www.layitlow.com/forums/index...owtopic=543538
On another note... ive heard it through the grape vine that after making my messurement out I should go back a little torts the back.. ???![]()
My 64 Impala Build:
Feed back:
that the shims out of the a-arm cross bar. then bolt the cross bar tight.
take whatever hole saw you plan to use (like for the aircraft setups I use a 2" hole saw) and space the hole saw 1/4" from the cross bar and drill. this way the cylinder dont his the cross bar and you dont need to do any lame shit like welding a piece of coil spring to the cross bar.
Aircraft Hydraulics, Custom Machined Hydraulics. 100% Made in the USA. New Product Line Coming Soon.
what I mean is that if i go out
1). 1/4 my cylinder will be more strait upwards ( when hole is cut and cylinder is installed ) it will be some what like this ( l¬ ) RED bein the cylinder and BLUE the cross bar.
2). if I do the 1/2 my cylinder will tilt some ( /¬ ) RED bein the cylinder and BLUE the cross bar.
Is that right or it dont really matter?
Haaa.. ok i think i gotcha right. Let me interpret that....
1) Put upper a-arms back on tight
2) Face the hole saw straight down like facing the floor (ground)
3) Place the hole saw 1/4" away form the cross bar torts the out side (using the wall of the hole saw to the cross bar as my guide)
4) And CUT
Does that sound right?
My 64 Impala Build:
Feed back:
I used to see a lot of cars with the a-arm bar notched just about 1/4" These were not hoppers. Frame reinforcement was not around back then so I can't say if it harmed the suspension in any way. Most riders I knew never keep their cars for very long anyways. Just stating something I seen in the 70's, not too sure if it applies to now.
Now in a larger font:
All comments/replies and posts presented by Hydros are to be considered educational and personal opinions, and relate to the level of education, ingenuity, experience, wisdom, intelligence, analytical abilities, imagination, sense of humor and general good will toward others.
All comments/replies and posts presented by Hydros are in no way to be interpreted as negative, slanderous or demeaning. All comments/replies and posts presented by Hydros are not meant to encourage those that feel the need to, yet fail to emulate Triumph, the Insult Comic Dog. Nor are comments/replies and posts by Hydros meant to encourage any member/s to display emotions that are elitist, negative, condescending, immature, insensitive and/or self-absorbing.
INTO OLD SCHOOL and HYDRAULICS? www.SquareDump.com SEE: see LIL post here...
For a fast reply, please no PMs,
email: tjjjc2@yahoo.com
Top rated book on learning Lowrider Hydraulics
Admin of www.hydros.biz www.pesco.us www.chevycamaro.com
THE MIDWEST IS DOIN THE MOST... It's that simple.
For HIGH QUALITY Hydraulic
Suspension Components & Frame work
PITBULL Hydraulics 502-367-1956
Liberals Suck!!!
"I" TO THE SKY
My car is dedicated to my best friend and fellow Lowrider Corey Mudd 1979-2002
TTT![]()
My 64 Impala Build:
Feed back:
TTT![]()
My 64 Impala Build:
Feed back:
ttt Im having the same problem. I even put washers on my arm and its still too tight .the cylinder fits straight up and they wont go into the spring.
here is my 2 holes that i drilled out. the right one has been reemed out more than the left. When I install the cylinder did goes vertical. it seems like if i cut out more there wont be much left on the frame.
Come on guys where's the help???
I went 3/8 from the shock hole then I cut with a 1-3/4 hole saw the cylinders are 1-5/8
Is it ok to run those shims on the a-arm bar?
