Refurbish your batteries yourself
Results 1 to 20 of 39
    Mar 2005
    T.O.
    6,007
    How To:
    anybody who's got a bunch of junk old batteries might want to try this out?!?! who knows?? its got me wondering... if anyone tries this and it works, let us know!
    http://www.ehow.com/how_4927788_refu...batteries.html
    Buying a new car battery can be fairly expensive, but it seems there is not much choice when a battery's performance plummets. However, in many cases you can refurbish car batteries and extend their usefulness. Doing so does not require pricey chemical additives. You can achieve the same results with magnesium sulfate, better known as Epsom salts. Car batteries are "lead acid" batteries with a solution of water and sulfuric acid. When sulfur collects on the lead plates of the battery, performance degrades. Magnesium sulfate can remove the sulfur and can restore a battery's performance.
    STEP 1:
    Loosen the battery cables with a crescent wrench and remove the battery. Use baking soda to clean the terminals and battery cables so you get good contact when the battery is reinstalled.
    STEP 2:
    Mix a solution of 1/2 gallon distilled water and 1/2 lb. Epsom salts. Stir until the salts are dissolved (if you use warm water this is a lot easier). Always use distilled water because the chemicals in tap water can damage a battery. Remove the battery cell caps and drain the water from the battery. If your car battery is of the sealed type, you'll need to find the shadow plugs (they'll be marked on the top of the battery) and drill through them.
    STEP 3:
    Use a funnel to fill each cell of the battery with the Epsom salt solution. Once you have filled each cell, shake the battery to make sure the solution is well distributed.
    STEP 4:
    Place the battery on a charger using a slow (trickle) charge for 24 hours. Remove the battery from the charger and replace the battery caps. For sealed batteries, buy plastic plugs from an auto parts store and insert them in the drill holes. Reinstall the battery and make sure the battery cables are properly fastened. Your battery should now work properly.
    STEP 5:
    Repeat the charging process two or three times over the next week to complete the refurbishing process. This helps to remove any remaining sulfur from the lead plates inside the battery. If you store the battery for a long time, place it on a trickle charger to prevent sulfur from accumulating on the plates again, as the battery drains while not in use.
    Dec 2007
    green river wyoming
    ROLLERZ ONLY
    513
    wonder if it works going 2 try it on some old ones i got laying around
    over it
    Feb 2006
    Michigan
    6,641
    Originally posted by lowrider_cutlass@Jan 4 2010, 03:53 AM~16177361
    anybody who's got a bunch of junk old batteries might want to try this out?!?! who knows??Â* Â* its got me wondering... if anyone tries this and it works, let us know!Â*
    STEP 1:
    STEP 2:
    STEP 3:
    STEP 4:
    STEP 5:
    That is not "water" it's highly corrosive battery acid that you will be draining out. Not a wise idea. It's not like there is a good way of disposing of that shit.
    Every knee will bow.
    All glory be to God!
    Mr. Paid
    Feb 2009
    SouthernCalifornia
    5,603
    Neutralize it with baking soda and dont breathe the gas it gives off.
    "Get your towels ready, it's about to go down."
    My 2002 Town Car build
    over it
    Feb 2006
    Michigan
    6,641
    No thanks. I'll buy new batteries when the time comes. If you properly charge and maintane the batteries from the start there is no need for all this. I put 12 PowerVolts in my boys Towncar 5 years ago and they are still going strong.
    The Canadian
    Jun 2004
    250
    7,793
    i have 18 old batts... hmmmm :0
    82 Cadillac Coupe Deville
    Smilies are worth a thousand words
    Jul 2006
    ROCHESTER N.Y
    UPSTATE C.C
    13,097
    There's nothing like biting off more than you can chew, and then chewing anyways!
    ♠------¡¡ƃuıɹǝqɯǝɯǝɹ ɥʇɹoʍ ƃuıɥʇǝɯos op-----♠
    In the game since 00
    Jul 2005
    the Icecoast of Saweedeeen
    ELEMENTS
    7,148
    1
    bah, humbug.
    "I don't fuck with quotes nor signatures."
    -Silentdawg
    Jul 2006
    ROCHESTER N.Y
    UPSTATE C.C
    13,097
    i had 10 referbished batts last me 7 years :0
    Oct 2006
    Tru Rydaz C.C.
    8,976
    That's a long time for refurbish. Plus it helps when you take good care of them.
    From: Hawaii Black Magic Hydraulics the best product by far!"
    We build our rides, we don't buy them"
    "Built tough with BMH stuff"
    ''Chearleaders are people too!''
    Tru Rydaz Car Club... uk texas new mexico hawaii Australia vegas
    Pj's 505 Customs New Mexico Black Magic dist
    Rj Customs west texas Black Magic distributor
    Build yourself something n stop ur cheerleading!
    HOME BREWED, NO HELP
    ~~~ THE STREETS OF K.C.MO~~~
    GOFUCKYOURSELF C.C.
    15,761
    throw it on the neighbors car... or barking dog....
    ~~~M.C.B.A.~~~
    ANYBODY CAN PAY SOMEONE TO BUILD HIM A CAR, A REAL RIDER DOES IT HIMSELF
    Science flies men to the moon, religion flies men into buildings.
    ~84 CADILLAC HEARSE~ blown motor
    ~ 90 CADILLAC HEARSE~ the parts hauler
    ~79 CADILLAC ~"The Big Green Bitch" ~, daily driver
    ''KANSAS CITYS FINEST'' FIRST PLACE FULL CUSTOM BIKE 2010 KC LOWRIDER TOUR STOP~STRIPED BY JUGZ~
    Oct 2006
    MODESTO, CA/HUGHSON, CA
    Luxurious CEN valley
    14,802
    not cool.......
    FTP: FUCK THAT PUTO
    (209 )996-5244 JEFF - KINGFISH_CUSTOMS
    (209) 535-4120 MINO - KINGFISH_CUSTOMS209
    Adex Original Aircraft Hydraulics
    (626) 798-2156 or email adexhydraulics@earthlink.net
    Oct 2006
    14,802
    haha..ya who loves a good cotail mix of chemicals....youll see on the headlines.....
    "LAYITLOW MEMBER FOUND DEAD BY FAMILY IN GARAGE AFTER TRYING TO REFURB HIS BATTERIES....next at 10 news followed by tiger woods nightly lol
    FTP: FUCK THAT PUTO
    Belen,NM
    VIEJITOS~Y~QUE!
    3,935
    "LAYITLOW MEMBER DUEZ PAIDFOUND DEAD BY FAMILY IN GARAGE AFTER TRYING TO REFURB HIS BATTERIES....next at 10 news followed by tiger woods nightly lol
    If we were only so lucky
    Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
    Belen,NM
    VIEJITOS~Y~QUE!
    3,935
    Originally posted by KINGFISH_CUSTOMS@Jan 4 2010, 01:23 PM~16180099
    not cool.......
    I agree with you for once
    GOFUCKYOURSELF C.C.
    15,761
    not cool.......
    also not cool that i have to listen to malnourished dogs bark 24/7 because the owner keeps them on his roof.....
    ~~~M.C.B.A.~~~
    Oct 2006
    14,802
    Originally posted by Reverend Hearse@Jan 4 2010, 03:03 PM~16180436
    also not cool that i have to listen to malnourished dogs bark 24/7 because the owner keeps them on his roof..... Â*
    thats what animal control is for...i cant stand to see dogs not fed cuz the owners aint feeding them..i have no problem with calling on people who dont take care of the dogs..(or animals)..the neighbor of a friend poisoned one of his dogs and it died a slow painful death from rat poisoning..so now im gonna go late at night and fuck their lawn up with some total vegetation killer..their lawn aint gonna go anywhere i spray it out at for a year lol
    FTP: FUCK THAT PUTO
    Oct 2006
    14,802
    see i knew we could find common ground somewhere
    FTP: FUCK THAT PUTO
    Mr. Paid
    Feb 2009
    SouthernCalifornia
    5,603
    Figured everybody in here would know about putting baking soda on battery acid, it's hydrothermic so you dont wash it off with water or it gets hot. If you get it on your hands, throw some baking soda on it and they'll stop itching. Also useful on hydrochloric acid if you use it to clean concrete.
    Mr. Paid
    Feb 2009
    SouthernCalifornia
    5,603
