madza b2000 86 with hydros
Results 1 to 9 of 9
    Oct 2010
    waukesha,wisc
    207
    i want the back lower what should i do
    i dont want c notch .the cylinders are welding to axle and i have 3 inch blocks and all leafs what should i do
    ]http://www.layitlow.net/pics/1010/3back ram.jpg[/IMG]
    Oct 2010
    waukesha,wisc
    207
    Oct 2010
    waukesha,wisc
    207
    sorry here is the pic link
    The Netherlands
    ROMANTICS CC
    3,976
    Damn, triple fail
    Oct 2010
    waukesha,wisc
    207
    thanks for that pic i could not load it but firefly found it so any help on what i should do
    Oct 2008
    NC
    393
    Wow... lets point out problems to address:
    1) You're relying on tack welds to hold your "cylinder mount" in place. Not good, should be full beads, seriously.
    2) You've got the cylinder mounted to high. I can't tell if you welded to a sleeve or the cylinder itself. If you welded to a sleeve, drop the rear and trim the sleeve 4" if you've got enough clearence room above the cylinder. This will have the frame sitting on the axle housings as it is right now according to your measurement of space between the axle housing and frame.
    3) You should have pulled the middle two leaves from the spring pack. This will get you lower as well. Leave the top leaf and bottom leaf aka the main leaf and helper leaf.
    4) Ditch the bump stop if you want to go as low as possible.
    Now, with that said, I'd really like to see the way you set up the front.
    May 2008
    NY, PA ,NJ,FL,MD,CT
    lowrider connection
    2,474
    Originally posted by tanguy34@Oct 23 2010, 01:19 PM~18887895
    i dont want c notch .the cylinders are welding to axleÂ* and i have 3 inch blocks and all leafs what should i do
    HOMIE WE GOT 2 OUR CLUB.. one is done wit the braket n the leaf spring wit 3/4 yellow coil from cce n the other one is done wit pawer ball n the rear n bricge both not c notched. . more info go 2 out forum lowriderconnection car club.
    LOWRIDER CONNECTION PA, NJ, NY, FL, CT, MD
    www.ccehydraulics.com
    www.lowrider-connection.net
    facebook rudylowriders
    myspace.com/lowriderconnection
    484 5381717
    May 2008
    NY, PA ,NJ,FL,MD,CT
    lowrider connection
    2,474
    484 5381717
    May 2008
    NY, PA ,NJ,FL,MD,CT
    lowrider connection
    2,474
    484 5381717
  11. Remove Advertisements
