car is 1991 Cadillac fleet wood running 2 pumps 6 batteries 12 switches. got the car all hooked up everything was working great for about 5 mins and now front end is not doing anything. all 12 switches are only running the back of the car now
Alright so i have swapped pumps replaced silinoids and still the same thing if i hit a switch for the front all i get is a soft sounding click coming from the dumps as for all switches hitting the back. That was my dumb ass .i was hitting pancake and seasaw so there is no issue there. I still have nothing to the front of car
Alright so i have swapped pumps replaced silinoids and still the same thing if i hit a switch for the front all i get is a soft sounding click coming from the dumps as for all switches hitting the back. That was my dumb ass .i was hitting pancake and seasaw so there is no issue there. I still have nothing to the front of car i also cracked the lines to release pressure
I checked all wires everything is tight and as it should be. Voltage looks good i swapped motors and still only getting back to hit. The only this im getting from the front is the silinoids click.
well if all the noids click you probably got bad ground. Try remove the pump and grind off all paint where it is supposed to be attached n try again.
Pump blocks are mostly made out of aluminum and that is not an ideal conductor to begin with.
I was raised by upper class white parents its crazy to think i wasnt raised around hydraulic cars. And trying to learn can be a pain when you dont know anyone that does it
do yourself a favor and read this book. It has everything you need from start to finish. have an understanding about how it all works, you should be able to fix anything in your system.
Related Threads
LayItLow.com Lowrider Forums
17.7M posts
191.1K members
Since 2002
LayItLow forum is an online community for true Lowriders. Come in and discuss hydraulics, air ride tech tips and all the information you need for dropping your lowrider.
