1993 fleetwood stero install help
Results 1 to 20 of 22
Like Tree1Likes
Thread: 1993 fleetwood stero install help
    May 2011
    Olympia,wa
    14
    Default 1993 fleetwood stero install help
    constant power wire
    i Have a 1993 fleetwood, and i can not locate a constant power wire. had wired to cigarette lighter but was causing bad battery draw.
    any ideas? also could somebody tell me if a 93 has a rear fuse box?
    May 2011
    Olympia,wa
    14
    also my accessories forward and backward positions dose not work? nothing not just radio?
    May 2011
    Olympia,wa
    14
    i know i can run a wire directly to battery but i would rather track down oem. because if im right my trunk fuse box is missing and i have a bunch of wires back there and a couple behind the deck. id like to get everything hooked back up to factory and functioning right. like my acc on ignition and a few other things. trying to work out all the bugs ghetto shit the last owner did.
    Mar 2013
    Las Vegas, NV
    Callejeros C.C. Las Vegas
    414
    There should be only 3 main wires you should be looking at
    Battery (yellow wire) constantly power on for stereo memory
    Ignition switch (red wire) anywhere around da fuse box or electric wire dat can be power on and off
    Ground (black wire) it can be connected to any ground surface anywhere that can be grounded best thing is sand it n screw it.....
    N da rest of da wires are speakers n amp remote.
    So find a tester n check on each wire with ignition on if light up then turn da keys off n turn it only for radio n if lite again then turn da keys to see if turn off n then da switch on n see if go back on n if does then u found an Ignition switch n now look for another wire n try again if light stay on even with da keys switch off then u found battery wire.
    Jul 2010
    Community
    1,005
    The12volt.com has all your speaker wiring needs! Free of course
    http://www.the12volt.com/installbay/...etail/395.html
    jun007 likes this.
    _____________________________
    Heaven and Hell?
    World wide suffering - GOD?
    H
    ate religion, Love Jesus
    _
    Jul 2010
    Community
    1,005
    The12volt.com has all your speaker wiring needs! Free of course: http://www.the12volt.com/installbay/...etail/428.html
    Heaven and Hell?
    H
    _
    May 2011
    Olympia,wa
    14
    Quote Originally Posted by Jeff Rohrer View Post
    Thank you, this helped. Help me to remember what a P.O.S my car is
    May 2011
    Olympia,wa
    14
    Okay its been a couple of years sense i wired this up now its coming back to me. The speaker wires do not match factory colors behind the head unit. in the rear passenger quarter panel i have tracked down the splice into factory wires. they run threw wire harness and come out behind head unit. there are no power memory or ground dimmer ect.
    Jul 2010
    Community
    1,005
    Quote Originally Posted by BigBody360 View Post
    Your last post had me laughing, been there too many times. Well it sounds as if someone has hacked the original wiring. Do you have a test light or digital multi meter? there both real cheap and can be had for a few bucks at a flee market or ebay.
    Heaven and Hell?
    H
    _
    Jul 2010
    Community
    1,005
    Also pics of the situation might help. with a test light or dmm you can find the 12+, switched or turned on from ignition 12+ and ground which is all you need to power up the radio which (Once you find those three we can search for the speakers or run them yourself.
    Heaven and Hell?
    H
    _
    May 2011
    Olympia,wa
    14
    When i got my car my stereo harness was hacked. Factory Amplifier was Gone, No connectors. I ordered a Bypass harness and male adapter to repair.
    After connecting harness in the trunk i am left with 8 wires. I need to what/where they go. i wrote down the colors in hopes somebody that knows could help me out.
    PINK, GREEN,GREEN/WHITE Stripe, GREEN/YELLOW Strip, RED/WHITE Stripe/ BLACK/WHITE Stripe, BROWN/WHITE Stripe, BROWN/ORANGE Stripe.
    May 2011
    Olympia,wa
    14
    I watched a video that said there was other accessories that run threw the factory amplifier. such as door chime ect. I am also having problems with my door chime, also i noticed when i work on stereo the my dash cluster will stop working. Then ill hop my car or something and they will start working. this last time the when they came back on my speed do was no longer registering and only reads 0 now? Not sure if it has anything to do with stereo. but reason i ask is i got a couple lose wires behind deck and i cant figure out where they go. i will get color for that later first thing first.
    727
    Sounds like you need to chase down some of those loose wires before you burn to the ground. Get a good wiring diagram and trace each wire.
    May 2011
    Olympia,wa
    14
    what ever they are they use to plug into the factory bose amp
    May 2011
    Olympia,wa
    14
    i do have the service manual for my car. I just dont know how to read schematics. but what im looking at right now says its basically the power and signals to the amp and info to the ecu-bcm whatever you want to call it
    Jul 2010
    Community
    1,005
    I know you may not want to do this but I'd take to a reputable shop, they shouldn't charge more the 125.
    Heaven and Hell?
    H
    _
    Jul 2010
    Community
    1,005
    The only other thing I'd recommend if you have in your area is going to a junkyard and cutting the stock plugs from a 93-96 brougham and match the colors up, then you can use the metra wiring bypass.
    Heaven and Hell?
    H
    _
    Jul 2010
    Community
    1,005
    Maybe here?
    http://www.picknpull.com/locations.a...=Detail&ID=171
    Call em they may have what you need
    Heaven and Hell?
    H
    _
    Aug 2014
    Mass
    81
    Are you going to use the factory amp or aftermarket? Either way the easiest way is to just buy the Metra harness and be done with it. Hot, switched, ground, dimmer, antenna, power antenna, remote, speaker wire it's all there.
    Jul 2010
    Community
    1,005
    Quote Originally Posted by Sberg View Post
    Someone cut his stock plug otherwise he could do this.
    Heaven and Hell?
    H
    _
