BOMB set up...need help
Results 1 to 4 of 4
    Apr 2006
    Hong Kong
    1,023
    Default BOMB set up...need help
    if anybody see this
    So I got a '48 Dodge which was rewired to 12v when I bought it. I was able to hook up a stereo to it but don't know how to get it turn off and turn on with the ignition. I mean the car has an ignition and a push button starter button as well. When I hook it up it just stays on. Also I dont know how to place my speaker since there were no kick panels...wanted to see if anybody has any pics of their bomb stereo setup. Thanks
    Ecclesiastes 12:13
    758
    You have to find a keyed power wire. May need a test lite for it. You are hooked up to a constant hot lead. You need that to hook up to the memory wire og the radio. It'll keep you presets set.
    Mar 2013
    Las Vegas, NV
    Callejeros C.C. Las Vegas
    420
    Black wire any where where is a perfect ground = ground wire.
    Connect da yellow wire straight to da battery = memory wire
    Connect red to a switch wire of ur ignition = ignition switch.
    "have a tester n check da fuse box n turn da keys to see if da tester light stay on and off every time u turn ur keys once u find da tester light goes off n on connect da red wire n check ur stereo to see if itgoes off n on with ur keys
    Apr 2006
    Hong Kong
    1,023
    Ok got it working. Wired red wire straight from the ignition. Now I got to figure out how to make the kick panels. I hate fiberglass...well working with it. Im going to try to make everything with wood. The back is where I still dont know where to put speakers without cutting anything up
  6. Remove Advertisements
