700r4 no 3rd or 4th gear HELP!
Results 1 to 5 of 5
    Nov 2005
    12
    PLZ HELP ME - THE CAR WOULD START HESITATING IN SECOND GEAR AT 3500 RPM YESTERDAY AND ONLY GO INTO 3RD IF YOU UPSHIFTED FROM DRIVE TO OVERDRIVE -- BUT NOW ITS DOWN ONLY TO SECOND GEAR GOING NO HIGHER THAN 2000 RPM AND THE CAR WILL NOT GO INTO THIRD OR FOURTH GEAR --WHEN IN SECOND GEAR --AFTER IT GETS UP TO 2000 RPM IT JUST JUMPS BACK AND FORTH LIKE IT WANTS SWITCH INTO THIRD BUT NOTHING I JUST HEAR LIKE A LOW ROAR IN THE TRANNY SEEMS LIKE VACUUM PROBLEM BUT THEN AGAIN IDK MUCH ABOUT TRANSMISSIONS TO BE COMPLETELY HONEST --- SOMEONE TOLD ME ITS THE GOVERNOR- ANOTHER SAID THE 3-4 CLUTCH IS BURNT OUT - EVEN ANOTHER SAID ITS A VACUUM LEAK -- PLEASE HELP - IM HOPING THE TRANSMISSION DOESNT NEED AN OVERHAUL BUT GIVE IT TO ME STR8 - I DONT HEAR ANY GRINDING AND THE FLUID IS CLEAN AND DOES NOT SMELL BURNT - ANY SUGGESTIONS, TIPS, HELP OR INFO WOULD BE GREATLY APPRECIATED - JAH BLE$$
    Jan 2005
    Sat Antonio, Tx
    ROLLERZ ONLY SAN ANTONIO
    16,520
    ur tranny is fucked
    sungear probably broke
    1995 Cadillac Fleetwood Brougham - "Lac Of Sleep"
    Yes sir, those be Daytons on the Lac
    CAR CLUB = NONE FAMILY = ROLLERZ ONLY
    ROLLERZ FOREVER FOREVER ROLLERZ
    THANKS JOHN AT KANDY SHOP CUSTOMS!
    Canada
    867
    It's the 3-4 clutches. Time for a rebuild, or swap it out for another one. Sorry...
    PARTING OUT Cadillac Fleetwood Brougham triple black with factory Astro
    1995 Impala SS Six Speed, 18" Anteras 275/295 MXs, Euro smoothie, AS&M headers, 4.10s
    1995 Roadmaster Wagon LT1 black, wood delete
    1994 Caprice Wagon LT1 power!
    1981 Cadillac Fleetwood Brougham D'Elegance Coupe OG on wires
    1971 Pontiac Parisienne 17" Weld billets, shaved, slam bags, D'Elegance seats
    1965 Impala convertible stock Cali black plate car, Maderia Maroon over black, 327/250HP, glide
    Jul 2008
    1,512
    time for a new one dont waster any more time triying to find out whats wrong get a good use one or get it overhaul, make sure to install shift kit,
    Aug 2001
    San Diego
    IMPALAS San Diego
    1,759
    had the same problem, band got burnt(apply solenoid wasn't adjusted properly, and the clutch drum did not have a flat surface. ended up burning up the band and clutches. had a homie rebuild the whole thing, replace the clutch drum and sun gear shell with heavy duty pieces and install a mild shift kit.
    ~JUNIOR~IMPALAS CAR CLUB~San Diego Chapter~
    '62 impala ss htp
    '62 impala rag
  7. Remove Advertisements
