1986 Monte Carlo steering wheel problem
Results 1 to 9 of 9
    Sep 2008
    20
    Unhealthy amount of movement/play
    I recently purchased a 1986 Chevy Monte Carlo in decent condition. I previously had a 1987 Olds Cutlass and I have noticed that the steering wheels on both seemed to be "loose". Both are tilt steering wheels and both cars drove straight, no wobbling, but it seems as if the column itself is loose/not attached correctly on the firewall. Any body have this problem or suggestions? I am afraid to drive it in this condition.
    Sep 2008
    20
    Oh, forgot to mention the car is stock with 86,000 original miles.
    Sep 2006
    220
    is the whole column loose or just the tilt section? If the whole column is loose then check the two bolts that attach to the underside of the dash, then check where is passes through the firewall. If its the tilt section you will need to take the wheel off and then tighten the torx srews in the column.
    Sep 2008
    20
    It seems as if it is the whole column. The tilt section seems fine. How is it supposed to be attached to the firewall?
    Dec 2007
    pocatello idaho
    UNIDOS C.C.
    87
    i had a car like that. it needed new bearing in it to plus the tightning it up.
    "Cadillac'N"
    1980 CaDiLlAc CoUpE
    1983 cutty "project" SOLD 1997 Cadillac Deville "daily driver"
    Sep 2008
    20
    It is not the tilt mechanism. It can be locked and I can move the column up and down.
    Apr 2005
    GA
    2,652
    Just look for the mounting bolts under the dash, if they are tight then its the column. There are 4 bolts in the column that are notorious for coming loose in G-bodies. Here are 2 write ups I found on a G-body website.
    http://www.fieros.de/en/articles/steering.html
    http://www.chevyasylum.com/column/tiltcol.html
    "Outside a dog, a book is man's best friend. Inside a dog, it's too dark to read." Groucho Marx
    xbox 360 tag: DO M DRTY
    Sep 2008
    20
    Thank you sir for the help. That is a very nice truck you have.
    Apr 2005
    GA
    2,652
    No prob, and thanks
  11. Remove Advertisements
