CHEVY 350 POPPING THREW MY CARB
Results 1 to 20 of 26
    ~RIP BIG MIKE~
    Nov 2001
    沖縄
    39,175
    I GOT A CHEVY 350 WITH EDELBROCK INTAKE HOLLY CARB,, WEN I PUSH ON GAS TO A HIGHER RPM THEN IT STARTS TO DO THE POPPING SOUND THREW MY CARB, IS THIS CAUSED BY 1 OF MY LOBES WORN OUT ON MY CAM SHAFT??
    LETS PRAY FOR OG KITA & PLEASE VISIT THE LINK AND DONATE http://www.youcaring.com/medical-fun...recovery/72997
    The repair manual
    Nov 2007
    Nebraska
    TRUESTYLE C.C.
    18,700
    depends
    Could be timing but if you havent messed with it in a while and it runs fine otherwise then probably not
    Could be worn out valve springs allowing the valves to float at higher RPM, in other words theyre not shutting all the way. Or a valve is bent or heavy deposits of gunk causing it not to close all the way.
    Ive seen lobes get wore down to nearly nothing and still work ok. Just no performance
    TRUESTYLE C.C. Topic
    Ride With Me
    409
    Sep 2007
    18,294
    If its missing, maybe the distributor is worn.
    1964 JET-SMOOTH LUXURY CHEVROLET
    ~RIP BIG MIKE~
    Nov 2001
    沖縄
    39,175
    ima fuck with the distributer and see wat i come up with, good info guys let me see wats up
    The repair manual
    Nov 2007
    Nebraska
    TRUESTYLE C.C.
    18,700
    yea check out all the points and such. If it just started happening you know something isnt wore down its more likely something broke. Like a broke valve spring or plug or wire or whatever.
    Ride With Me
    Feb 2005
    SKRAPEHOUSE CC
    6,477
    Originally posted by CoupeDevilleDTS@Feb 5 2009, 02:09 PM~12914634
    depends
    Could be worn out valve springs allowing the valves to float at higher RPM, in other words theyre not shutting all the way.Ā* Or a valve is bent or heavy deposits of gunk causing it not to close all the way.Ā*
    Ive seen lobes get wore down to nearly nothing and still work ok.Ā* Just no performance
    co-sign
    but need a little more info, have you done anything to the engine lately,
    did you change the cam and not the springs? I've done it and that is sounds like exactly what happened, worn valve springs.
    Bad vacuum advance?
    distr. 180 out?
    so it runs fine at lower RPM until you step on the gas??
    I think coupe de ville hit it right
    Bay Area freeway rider
    Aug 2005
    co co county
    EXCANDALOW
    9,930
    i lost a few teeth on a timming chain before, pull the dist cap off and see if the rotor is going aroung smooth or if its jumping around. i guess alot of the early 70s 350s lower timming gear was aliminum with nylon teeth. i changed the timming chain and found a few bent valves so i ended up putting heads on it.
    1964 Impala ss
    1966 Impala http://www.layitlow.com/forums/index...owtopic=450818 SOLD
    1969 Imp rag http://www.layitlow.com/forums/index...owtopic=510089
    1976 Caprice Glasshouse
    dont fool yourself 4 doors are parts cars
    Apr 2007
    Inland Empire
    GROUPE RIV. CO.
    4,425
    LOOKS LIKE WE ALL AGREE IT'S TIMING RELATED.
    GROUPE RIVERSIDE COUNTY, ESTABLISHED 1989
    TATTOO MEMBER SINCE 1995
    The repair manual
    Nov 2007
    Nebraska
    TRUESTYLE C.C.
    18,700
    We all agree to rebuild also
    Ride With Me
    ~RIP BIG MIKE~
    Nov 2001
    沖縄
    39,175
    Originally posted by 64_EC_STYLE@Feb 6 2009, 09:30 PM~12929980
    co-sign
    but need a littleĀ* more info, have you done anything to the engine lately,
    did you change the cam and not the springs?Ā* I've done it and that is sounds like exactly what happened, worn valve springs.
    Bad vacuum advance?Ā*
    distr.Ā* 180 out?
    so it runs fine at lower RPM until you step on the gas??Ā*
    yea wen i drive low rpm its good but higher rpm it do the popping threw the carb, i got the bottom half of the motor done, but even before that is was doing it
    Feb 2005
    SKRAPEHOUSE CC
    6,477
    Originally posted by 64 CRAWLING@Feb 7 2009, 06:08 PM~12935811
    yea wen i drive low rpm its good but higher rpm itĀ* do the popping threw the carb, i got the bottom half of the motor done, but even before that is was doing it
    assuming that when you say the bottom half was done there is a new cam w/ timing chain and gear set, which leaves the timing(in which we all agree)
    I would start with vacuum advance, just for GP, and then change out those valve springs.
    In the case that the cam set hasn't been changed out, I would invest in a cam kit with cam, lifters, valve springs and seal for around $300(assuming you do your own work because this would be expensive at a shop for an easy fix)
    ~RIP BIG MIKE~
    Nov 2001
    沖縄
    39,175
    new timing chain, rear main seal and crank shaft, the cam and lifters still the same
    ~RIP BIG MIKE~
    Nov 2001
    沖縄
    39,175
    Originally posted by 64_EC_STYLE@Feb 8 2009, 12:46 AM~12938356
    [/size]
    yea i guess i have to buy the set and hope that works
    ~RIP BIG MIKE~
    Nov 2001
    沖縄
    39,175
    yea pulled my valve covers and the left side on the 4th rocker it aint moving at all
    Jun 2007
    Zanesville OH
    4,689
    did you over tighten your rockers? that will do it too(learned that the fist time i rebuilt a small block),other than that it sounds like your timing gears arent lined up right-you can try the distributor but sounds like timing is off via timing chain gears-if you get those off it will open an intake valve during comprssion stroke therefore blowing thru your intake and carb
    bags get big wheels-gimme D'z and a lead hammer!!
    racing hondas is like the special olympics:even if you win you're still fuckin retarded!!
    my feedback------- http://www.layitlow.com/forums/index...owtopic=370031
    Jun 2007
    Zanesville OH
    4,689
    that is a bad lifter or too short of a lifter rod,that should just make it run like shit(7 cylinders working right) shouldnt cause blow back
    ~RIP BIG MIKE~
    Nov 2001
    沖縄
    39,175
    yeah it dont feel like it got alote of power but still drives gud though, i struggle to go up a hill though lol
    Oct 2007
    497
    Same problem that I am having with my ht4100
    ~RIP BIG MIKE~
    Nov 2001
    沖縄
    39,175
    THATS YOUR PROBLEM ITS A HT41OO
    Sep 2007
    Nanaimo BC
    AFFILIATED C.C.
    2,967
    lol
