ELECTRIC COOLING FAN WIRING ?
Results 1 to 20 of 29
    Mar 2002
    618
    SOCIOS cc. STL
    6,814
    i bought a 16'' chrome electric cooling fan from ebay it came with the relay and temperature switch and didn't come with no wiring diagram...i tryed wiring it one way and it never kicked on the way i wired it anyone have any idea on the correct way to wire it ? on the relay looks to be 2 red hot wires and ground...and the temp switch is just one prong
    Top dollar with the gold flea collar dippin' in my blue Impala [DPG]
    Feb 2009
    Bryan,Tx
    La Compania
    155
    dude tell u the truth just rig it up and get a switch so when ever u crank the car up hit the switch when ur drivin that all i know that how i have mine but mine diffrent one i order from ebay!
    LIl Hamburger
    Mar 2002
    618
    SOCIOS cc. STL
    6,814
    your the second one to tell me that too,lol looks like what i might have to do unless the third person tells me the correct way
    Oct 2007
    San Fernando Valley
    USO San Fernando
    252
    Well homie, you're in luck. Here's the correct way to connect it so it will work automatically. A switch is ok, but you only want your fan on when your engine reaches optimal heat range. Get a notepad n pen homie. I run my dual electric fans this way.
    Look at your relay and notice it has numbers next to each tab.so connect as follows
    #87 Power from battery (use an 8 gauge wire)
    #30 Connect to positive fan wire (use 8 gauge wire)
    #86 Connect either wire from temp sending unit
    #85 Connect either wire from temp sending unit
    Then start your car and watch to see that fan comes on around 185 degrees.
    Also, make sure if fan is behind radiator, that it is pulling air. If it's in front of radiator (between grill and radiator) then you'll want to reverse the positive wire and ground wire on fan. Then you'll be cool
    OLDSKOOL ART CUSTOMS 818-414-1968 1 YEAR ANNIVERSARY FOR THE SHOP! SEND REFERRALS. THANKS
    Never been a BACKSEAT BUILDER...Clock started tickin' when wrenches turned on my own ride for the first time. Never claimed a club I wasn't from either. USO4LIFE! 1 of only 4 real USOs in SFV
    Diggin' the scene with a gangsta lean...
    68 Caprice "Mr.Simplistic" in LRM Sept, Oct, and Dec 2009 Issues
    65 Impala "Palita"
    53 210 "Project 'Bel"
    47 Fleetmaster
    "Doin It Big" for a future USO JP R.I.P.
    Feb 2009
    Bryan,Tx
    La Compania
    155
    now that the right way to doin it homie now ima rewire mine and do it that way!
    LIl Hamburger
    Apr 2004
    3,179
    Mar 2002
    618
    SOCIOS cc. STL
    6,814
    right on i am going to try it out i will post back up and let you know if that works or not....thanks
    The repair manual
    Nov 2007
    Nebraska
    TRUESTYLE C.C.
    18,713
    THere is a right way to do em like the man posted but Ive done it before and the fans never turned on, either bad sensor or relay or whatever, ended up just doin a switch too.
    TRUESTYLE C.C. Topic
    Ride With Me
    Mar 2002
    618
    SOCIOS cc. STL
    6,814
    wired it up that way will post up and let yall know later if that way worked too late to run it right now
    Mar 2002
    618
    SOCIOS cc. STL
    6,814
    never came on
    Apr 2007
    Inland Empire
    GROUPE RIV. CO.
    4,425
    #85 ignition power, key on only (+)
    #86 thermal switch, temp. switch that screws into the cooling system (-)
    #87 power from the battery fused (+)
    #30 cooling fan positive power feed (+)
    This is how I've done them in the past.
    GROUPE RIVERSIDE COUNTY, ESTABLISHED 1989
    TATTOO MEMBER SINCE 1995
    Mar 2002
    618
    SOCIOS cc. STL
    6,814
    thanks for all your help....finally got it going right
    this how i wired it
    #85 & #30 jumped together and from that i have on my Ignition Key Accessory +
    #87 To Electric cooling fan +
    #86 To the Temperature switch
    here is little diagram i made up on how i have it wired
    Apr 2005
    Dirty Jerzy
    1,801
    A2P
    Absolute Audio & Performance
    63 Impala For Sale
    My 63 PIMPALA Build
    http://www.layitlow.com/forums/index.php?s...post&p=10921721
    http://www.pitbullhydraulics.com/
    Pflugerville,Tx
    1,274
    What if you have a two speed fan,I want it to run on low and when ac is on,run on high,on a 307 motor what type of temp switch do i buy?
    Apr 2007
    Inland Empire
    GROUPE RIV. CO.
    4,425
    Not a temp. switch, but a relay to trigger the 2nd speed upon a/c request.
    Apr 2007
    Inland Empire
    GROUPE RIV. CO.
    4,425
    this how i wired it
    #30 needs to go straight to the battery ,'cause it's a load carring circuit. Get it off your ignition switch. IT'S NOT SAFE. Now you can keep 85&30 together straight to the battery, and when you turn off the car if the motor is still hot the fans will stay on with the key off untill the engine cools off. DON'T FORGET TO FUSE 30 & 85.
    Apr 2007
    Inland Empire
    GROUPE RIV. CO.
    4,425
    this how i wired it
    Mar 2002
    618
    SOCIOS cc. STL
    6,814
    yea after i ran it i turned off the motor and went back to accessory and the fan kept going until i turned the key to off position...i really don't like the fan running after the car is off
    Mar 2002
    618
    SOCIOS cc. STL
    6,814
    this way you explained how would the fan run,would it still run after car is turned off? see i tryed this way but my harness for the relay came jumped #30 to #85 didn't know there is different ways to wire it...im good with wiring but relays always confused me i dunno much about them
    Apr 2007
    Inland Empire
    GROUPE RIV. CO.
    4,425
    The fan will turn off when you turn the key off.
    #30&#87 are the load side of the relay,one supplies voltage to the fan the other to the battery to get power.
    #85&#86 are the control side of the relay to turn the relay on/off.
