700R4 TV(Throttle Valve) Cable Installation Help
Results 1 to 9 of 9
    Jun 2009
    48
    Engine & Trans allready installed
    Can anyone provide a good step by step link or pictures on how to install and adjust the TV cable for a 700R4 to a Rochester Quadrajet Carb? Cant ride without it. Thanks!
    1964 IMPALA SS Buildup with an aftermarket 454 Big Block!
    Aug 2004
    B.F.E, 803
    i do this for me,no one else
    14,840
    you need the brackets to mount the cable,and the bracket to correct the geometry of the swing if its not original to the carb. once the cable is mounted correctly. push the button it and slide teh cable all the way back,or to where its loose, then push the gas pedal to the floor to pull the cable back out. it supposed to set by its self
    friends dont let friends drive g-bodys
    http://www.layitlow.com/forums/index...owtopic=162717
    great deals on motocross parts
    http://www.privateerconnection.com/index.htm
    Jun 2009
    48
    The engine & trans are already installed in the car so hooking the cable up to the transmission would be to the hard part. Would I have to drop the trans to get the cable plugged in since 3 1/2 in exhaust pipes blocking the way? Thanks! for the other advise though!
    Aug 2004
    B.F.E, 803
    14,840
    you have no line /cable coming from the trans now?. ya that lines gonna be a pain in the ass to hook into the trans if you cant get to it.and dont run it without it hooked up and adjusted right, it wont last 5 minutes
    Jun 2009
    48
    So me and my bro spent a good 6 hours in 15 degree weather trying to put the cable on the kick down hook in the transmission every time we would get it on and gently pull the cable it would come off. Any suggestions?
    Aug 2004
    B.F.E, 803
    14,840
    it should have a loop bent into i think, and the cable had a hook on it, its been a while i cant be sure,grab it with a pair of needle nose vise grips and hook it
    Jun 2009
    48
    Yeah it does have a hook on it so I we got it connected but now the problem I'm running into is the bolt that locks it down LOL not enough room to do anything so I'll have to figure that out. The hard part is over thankfully. I'll keep you all posted!
    Aug 2004
    B.F.E, 803
    14,840
    drop the cross member and lower it down a lil bit
    Jun 2009
    48
    I tried that but I still didn't have room because there are custom 3 1/2 inch exhaust pipes on the side of it. So I found a rather unconventional way of tightening the bolt.
    1. Put multiple socket extensions together to make a 3 ft long extension.
    2. Then on the end of the socket extensions put a flexible extension.
    3. Run the extension down the right side of the distributor at an angle towards the transmission.
    4. Have a friend hold the socket in place on the bolt while you tighten from the top.
    Sounds crazy but it works.
  11. Remove Advertisements
