93 fleetwood wont start
Results 1 to 20 of 30
    Mar 2009
    5,309
    turns over no go
    Ok been fightn this pass key fault shit I thought I fixed it but now when the car cranks its fine but if the car sits a day or so and go to crank it it just turns over... I used carb cleaner but nothing just turns do you think it has something to do with the pass key fault or is it a fuel pump,carb, ect problem any help would be great thanks
    May 2009
    568
    My 93 does the same thang I put a new ECM and fuel pump checks fues and relays and still nothing its going to the shop after the first.And when they fix it I will let you know. Good Luck With yours
    Mar 2009
    5,309
    I've been fighten the pass key fault shit I think it has something to do with that it was just running wednesday...
    Moderator
    Nov 2001
    LOS ANGELES
    MAJESTICS L.A.
    54,754
    TRY MESSING WITH THE TILT YOUR KEY IS PROBABLY NOT MAKING GOOD CONTACT,,IVE HAD THE SAME PROBLEM
    CENTRAL DRIVESHAFTS AND CHROME
    hit me up for all your driveshaft needs
    SPECIALIZING IN DRIVESHAFTS,CHROME,,BATTERIES
    PM FOR PRICES
    Mar 2009
    5,309
    Originally posted by Big Rich@Dec 25 2009, 06:29 PM~16088986
    TRY MESSING WITH THE TILT YOUR KEY IS PROBABLY¬* NOT MAKING GOOD CONTACT,,IVE HAD THE SAME PROBLEM
    I put a new lock switch and cylinder in it I got a key without a chip.... So do you think its the key shutting down the fuel pump I thought with pass key fault car wouldn't do nothing? Thanks plus I have no light on at all?
    Canada
    867
    Take off your air cleaner assembly. Have someone crank the car while you look closely at the bottom of the injectors. If there is no fuel coming out of them while you crank, it is either the fuel pump relay (not likely) or the fuel pump (very likely). When you first turn the key to RUN (without turning it to START), do you hear the fuel pump prime for two seconds? If no, it is time to replace the pump. To double check the relay, you can swap it with the AC relay. Both are right behind the passenger tire near the firewall.
    PARTING OUT Cadillac Fleetwood Brougham triple black with factory Astro
    1995 Impala SS Six Speed, 18" Anteras 275/295 MXs, Euro smoothie, AS&M headers, 4.10s
    1995 Roadmaster Wagon LT1 black, wood delete
    1994 Caprice Wagon LT1 power!
    1981 Cadillac Fleetwood Brougham D'Elegance Coupe OG on wires
    1971 Pontiac Parisienne 17" Weld billets, shaved, slam bags, D'Elegance seats
    1965 Impala convertible stock Cali black plate car, Maderia Maroon over black, 327/250HP, glide
    Mar 2009
    5,309
    Originally posted by jayoldschool@Dec 25 2009, 08:27 PM~16089590
    Take off your air cleaner assembly.¬* Have someone crank the car while you look closely at the bottom of the injectors.¬* If there is no fuel coming out of them while you crank, it is either the fuel pump relay (not likely) or the fuel pump (very likely).¬* When you first turn the key to RUN (without turning it to START), do you hear the fuel pump prime for two seconds?¬* If no, it is time to replace the pump.¬* To double check the relay, you can swap it with the AC relay.¬* Both are right behind the passenger tire near the firewall.
    Ok I took the top off and spary come carb cleaner but nothing and I put to start I don't hear nothing ill check the relay is it under the hood on the passenger side? Thanks for the help and is the fuel pump in the gas tank? I hope I don't have to drop the tank that would suck.... Thanks for the help and u don't think it has anything to do with the pass key fault I have no light but I did before I replaced the lock,switch,and cylinder..
    Canada
    867
    Pass key won't let the starter crank at all, so no, I don't think that is the problem.
    No gas came out of the injectors when you cranked? Can't hear the fuel pump prime when you turn the key? If no to both, then it is likely a bad fuel pump, and yes, you need to drop the tank. Replace the in-tank wire harness while you are in there.
    Mar 2009
    5,309
    No gas came out of the injectors when you cranked?¬* Can't hear the fuel pump prime when you turn the key?¬* If no to both, then it is likely a bad fuel pump, and yes, you need to drop the tank.¬* Replace the in-tank wire harness while you are in there.
    Ok cool where is that relay ill check that before I drop that tank hopfully that's it if not ill drop the tank thanks again
    May 2009
    568
    It should be on the pass side wheel well under the hood.If you do have to drop the tank you can take the fuel lines off the fuel pump first by taking off the lines are in front of gas tank then drop the tank.
    Mar 2009
    5,309
    Cool hopfully it will be the relay
    Mar 2009
    5,309
    Ok went out this moring checked fuses in the car and under hood there is was blown fuse for the power locks inside and under the hood the air ride is blown but I dissconnected the air ride because of my hydros plus I swapped out relays and still nothing. I can't hear the fuel pump prime or nothing I hate to drop the gas tank and its the pass key shit the hole time what should I do ? Thanks
    May 2009
    568
    Go and unplug the fuel pump by the back bumber and put power to the fuel pump and if you can hear it run then you know it works.
    Mar 2009
    5,309
    do you think its the key that killed the fuel pump i sprayed some carb cleaner in there and still didnt try to turn over?
    May 2009
    568
    Check for spark.Try putting gas down the carb. On my 93 I change the fuel pump and even put a nother steering colum in it and still did not start.But when I put gas down the carb it would start.Im taking mine to the shop on the first.
    Mar 2009
    5,309
    yep pour alittle just alittle and nothing..most cars if you pour some it will at least burn that out then turn off...mine does nothin......
    May 2009
    568
    Did you check for spark?
    Mar 2009
    5,309
    how do you do that???
    Detroit
    MOTOR CITY RIDAZ
    1,106
    Well, I would start by removing the coil wire from the distributor cap and sticking a phillips screwdriver in the end. Then place the screwdriver near the manifold (dont hold it just set it down). Have a friend crank it while you watch under the hood and if you have spark, you will see spark arc/jump to the manifold.
    IF you get spark that way, then pull one of the plug wires from the spark plug and repeat the process.
    Be safe and good luck
    "everybody that has a lowrider, aint one"
    May 2009
    568
    It takes to people.Take a spark plug wire off the cap and rotor and hold the boot about 1/8 of an inch away from the stud on the rotor and hold it and the other person start the car and you should see a littel spark inside the boot of the spark plug wire and the stud of the rotor and be carefull it might shock you.Or take the coil off and go get it tested at a auto store.
