priming a power steering pump
Results 1 to 4 of 4
    Nov 2005
    THE 307 [ WYOMING ]
    Rollerz Only
    3,596
    How do you actually prime a power steering pump ? Iput fluid in the pump and the front tires are off the ground belt is tight. But no fluid circulating through the pressure hose and i know this because i even disconnected the hose to the gear box and no fluid coming out of it. This is on a 64 impala with the 605 conversion brand new pump also. I dont know what im missing here.
    The Takedown ACE
    The repair manual
    Nov 2007
    Nebraska
    TRUESTYLE C.C.
    18,691
    never heard of priming. Buy it, put fluid in it, take the wheels off the ground, with the car off turn the wheel both ways over and over and over the fluid will rise and fall and release air. Run the motor and the pump starts to pump and thats all. If you have the wrong pulley on it, maybe the pulley is turning but not grabbing the shaft?
    TRUESTYLE C.C. Topic
    Ride With Me
    Jan 2010
    The OC
    389
    What he said.
    You may have to repeat it a few times. Mine took 2.5 times before the power came on. Spilled a lot of fluid in the process as the burps caused some overflow.
    The process that came with my pump rebuid was
    jack front wheels off the ground.
    Engine off- gently turn steering wheel lock to lock several times
    Engine On -gently turn steering wheel lock to lock several times
    Repeat until it is powering the steering.
    1964 Impala 4 door sedan
    Nov 2005
    THE 307 [ WYOMING ]
    Rollerz Only
    3,596
    i will try it that way thanks guys hope this works for me
    The Takedown ACE
  6. Remove Advertisements
