wrong gap size on spark plugs
Results 1 to 16 of 16
    Mar 2004
    BAKERSFIELD,CA
    524
    what is the worst could happen
    I put in the wrong gap size on spark plugs and now my car wont stay on or is hard to start and when it does start gas come of the the carb so I need some big help.
    shit
    Apr 2004
    San Diego
    221
    why don't you just re-gap them? I think you already know the worst that could happen
    Sep 2003
    The Small Apple
    715
    the worst that could happen, is that you get clowned on the internet for not having a $.99 gapper, forget having a ride thats out of tune
    let me know if i am on here too much
    Mar 2004
    BAKERSFIELD,CA
    524
    [snapback]2660702[/snapback]
    It wasnt that I didnt have a a gapper because I did it was the first time me giving a tune up and the new spark plugs gaps was all ready gap to much I didnt want to do nothing to the spark plugs to make stuff worst than it is so I dont know what you talking about gettion clowned
    shit
    Apr 2004
    San Diego
    221
    all you got to do is tap them on something metal or hard surface, and the gap will reset.
    Aug 2001
    San Diego
    IMPALAS San Diego
    1,759
    what car are you working on? the gap might not be the problem, you may have reinstalled the spark plug wires on the wrong plugs, or maybe knocked off a vacuum line ?
    ~JUNIOR~IMPALAS CAR CLUB~San Diego Chapter~
    '62 impala ss htp
    '62 impala rag
    Mar 2004
    BAKERSFIELD,CA
    524
    [snapback]2660929[/snapback]
    it is my regal with a 3.8 motor what do you mean reinstalled the spark plug wires on the wrong plugs
    does the size of the wires have to do with it because I could have that worng
    shit
    DON"T STOP NOW
    Apr 2004
    BRODERICK
    LO*LYSTICS CC
    393
    I agree. Make sure your wires are in the right plugs. Most times plugs will be OK right out of the box.
    ~LO*LYSTICS NORTHERN CALIFAS~
    Triple OG
    Mar 2002
    The Chi
    Concrete CC
    10,991
    sounds like timing is not right.
    Oct 2001
    Canada
    12,921
    [snapback]2660893[/snapback]
    if u do this be gentle. u could bust them easy if ur not.
    dunno what he means by it will reset the gap. all it will do is make the gap smaller.
    i'd say gap them to spec and u shoul be just fine
    as for worst thing that could happen. well what your experiencing is about it i believe. well iguess absolute worst would be it not running.
    layta
    530, 916
    Brown Society
    3,995
    [/b]
    <!--QuoteBegin-ogbrkboy
    @Jan 30 2005, 04:30 PM
    I agree.Â* Make sure your wires are in the right plugs.Â* Most times plugs will be OK right out of the box.
    [snapback]2661042[/snapback]
    This is a good answer. Most plugs are gapped good enough for all hei's which is what you have. I would check your firing order and also all vacuum lines.
    I think everyone that has a hopper should hit their own switch.
    Click here to see a few videos.
    Sep 2002
    Sacramento, California ~916~
    2,523
    A good rule of thumb to start is .035". Which pretty much is when you take a matchbook cover and fold it once. It should slide in the gap with alittle drag. That is the easiest to check. Then while your at it, check to make sure you didn't swap aound a few plug wires. It needs to fire certain plugs at a certain time. I have done it quite often.
    As you say it ran fine before the plugs, so it has to be one of those things. Or you may have a bad plug/wire.
    -->leav'n frame marks across the streets of cali<--
    Inventor of the:
    "Air Shock System" & "Rock-Steady Rear End"
    Business:
    ~~I do custom juice, air and hot rod creations. Restorations, interior, body, engine/EFI, frames, parts fabrication. Also, go carts, mini-bikes, trikes, and just anything you can imagine, I can make it for u. For estimates and or ideas email me with your info. (cmallmotorsports@yahoo.com) C-M-ALL Motorsports. Chris~~
    Jan 2005
    808 Hawaii ~ 909 Cali ~ 210 Texas
    2,795
    tyhe gap is not that big of a deal as some people think. you dont wanna have no space in between it though. one thing it could be is BOSCH plugs... they are NOT meant to be used in newer model gm vehicles. i work for a chevy service dept. and this situation arises all the time. when we tell the customer it was the plugs they just replaced they are usually shocked. but its true about bosch.
    As an American I am not so shocked that Obama was given the Nobel Peace Prize without any accomplishments to his name, but that America gave him the White House based on the same credentials." - - Newt Gingrich
    Triple OG
    Mar 2002
    The Chi
    Concrete CC
    10,991
    [snapback]2672577[/snapback]
    how new?
    i got a 96' and I have bosch plugs in it.
    Jan 2005
    2,795
    once gm started using the 3100, 3400 and 3800 v6s. those are the worst to use bosch in. i forget what the first year of the 3100s were but its somewhere around 88 or 89. when i bought my 97 monte carlo it had brand new bosch plugs in it that the previous owner put in. the car always ran like crap. i changed them and found them to be platinum 4s. they were waisted and less than 4 months old.
    Sep 2002
    2,523
    I'll be honest, I find that hard to believe. I can see it maybe with the 4's, cause the spark kernel is not as open to the chamber like a single plug head. But that would be the case for any vehicle. I use the original Splitfire, and for the money $4-5 a plug they do work great. I also recommend the original Bosch Platinum. Not the +4 style.
    Anyways we are off of the point here. The only thing I can suggest that will tell us what is wrong is to install the old plugs back in and see how it runs. If its better, then you need to re-gap the plugs and put them back in, or you have a bad batch and have to get a new set.
    Inventor of the:
    Business:
  18. Remove Advertisements
