car starts but wont stay idling
Results 1 to 16 of 16
    Nov 2010
    valley of the guns, AZ 480,928,520,623,602
    4,510
    Default car starts but wont stay idling
    this is on my daily. a 92 chrysler imperial
    3.8 v6 fuel injected
    car runs excellent, out of nowhere went to
    start in morning and turns over but wont stay
    at idle . i did run it down to almost completly
    empty before putting gas the night before.
    it turns over but immediately shuts off.
    if i feather the gas quickly it will kinda idle
    but as soon as i let off it dies. I tested the
    fuel pump wth the fuel pump tester from autozone
    and fuel pressure was fine. any help would be appreciated
    homies.. thanks
    from the center of AZtlan
    I like my low like I like my women, ass up... face down
    The Netherlands
    ROMANTICS CC
    3,986
    Idle control valve? Or a vacuum leak somewhere.
    Nov 2010
    4,510
    k. i'll check that when i get home.. thanks homie.
    Jun 2007
    TEXAS
    INDIVIDUALS cc
    1,617
    first chech for vacuum leaks.
    Nov 2010
    4,510
    Update. i removed the air cleaner and sprayed starter fluid into the throttle body. the car starts and revs like normal for a few seconds then dies. so it looking like its fuel related . the fuel pressure did test in the normal range at the fuel rail located after the regulator
    Mar 2010
    billionare mafia
    5,306
    fuel filter, fuel pump why not just get them out the way. junkyard fuel pump works good as well
    Moderator
    Jun 2005
    Chicago, IL
    16,025
    Quote Originally Posted by joeycutlass View Post
    Why would he replace the fuel pump when he's tested it and it's making the pressure? Fuel filter, yeah thats a good idea if its due for one or don't know the last time it was replaced but that's before the regulator and fuel rail so even if it's dirty he's still getting proper pressure so its not clogged. Pump, regulator, filter have been ruled out so why replace them?
    "Too Many Dreamers, Not enough Builders"
    My Feedback Topic
    Mar 2010
    billionare mafia
    5,306
    yeah didn't read the hole thing fuel pumps ok. something else it could be plugged injectors try aditive in the tank and rev the shit out the car
    Nov 2010
    4,510
    replaced fuel filter already.. i added a fuel additive.. i cant rev the shit out of it cuz it will only slightly rev when i feather the pedal.
    i sprayed starter fluid directly in the air intake and it revved high like normal, then died after starter fluid used up, so its a fuel pruoblem im pretty sure.
    Wheel King Inc.
    Sep 2010
    -BLACK EAGLE-
    6,592
    Quote Originally Posted by playboi13 View Post
    Check the map sensor
    *ROLLIN ROUND ON THEM OG ROADSTAR 72's*
    ~My FEEDBACK~
    http://www.layitlow.com/forums/28-fe...-robinson.html
    Mar 2010
    billionare mafia
    5,306
    just swap parts and get the codes checked might not show anything but they do it for free
    autozone rents the code tester so you don't have to drive to the parts store
    Nov 2010
    4,510
    its a 92... obd1 .. autozone dont have the obd1 tester
    Moderator
    Jun 2005
    Chicago, IL
    16,025
    Paperclip and count the flashes on the dash or cheapo $30 obd1 code reader, well worth the $$$. I would NOT just start swapping parts, properly diagnose it then fix the actual problem rather than throwing $$$ at it.
    My Feedback Topic
    Nov 2010
    4,510
    Quote Originally Posted by *ROADSTAR*ROBINSON View Post
    thats exactly what it was homie.. towed it to pepboys. they ran codes.. i swapped out map sensor.. runs like champ
    thanks to all the homies..
    Nov 2010
    4,510
    New problem yay. now won't start without priming first. them once started feels like its not getting adequate gas. recently changed map sensor from last prob.
    Mar 2010
    billionare mafia
    5,306
    fuel filter, or vacuum leak
  18. Remove Advertisements
