HOK SG-150 QUESTION?
Results 1 to 20 of 22
    ETOWN, KENTUCKY
    SOLO
    21,876
    can Flakes be sprayed over hok pearl?
    i know this is a dumb question but im curious about mixin some medium hok violet flakes with sg-150 flake carrier from hok and spraying it over hok passion purple!
    Big doe has done the same color with lincoln james old town car but instead of flakes he went with violet ice pearl in sg-100 intercoat, im anxious to find out and see if adding some decent size violet flakes will work with that hok passion purple as well!
    i know candy needs to be sprayed over flake , ut i have a feeling that violet flakes probably wouldnt look bad in the sg-150 then just cleared over with topcoat clear?
    heres the color with violet ice pearl big doe did, pretty huh!!
    never represent something that doesnt represent u...
    My 84 cadillac project- http://www.layitlow.com/forums/index.php?s...pic=210617&st=0
    check out my work @ TOPNOTCH POLISHING..
    specializing in anything aluminum
    http://www.layitlow.com/forums/index.php?s...post&p=12822122
    Mar 2003
    Victoria BC
    None
    5,046
    i dont understand the question billy????? are you wooried about compatability ussues, cause there wont be any there.
    Done, maybe? Sorta, almost,obo, idk
    my 6deuce build up thread
    ETOWN, KENTUCKY
    SOLO
    21,876
    yes, ok heres what im trying to do seal with white or black sealer, spray 4 coats of passion pearl basecoat,then mix sg-150 with violet flakes and spray, then topcoat clear? will this work i just dont know how long of flashes or coats are needed, i have no problem with wetsanding and reclearing for a deeper look!
    ETOWN, KENTUCKY
    SOLO
    21,876
    Originally posted by LUXURIOU$LAC@Dec 28 2007, 12:38 AM~9547617
    yes, ok heres what im trying to do seal with white or black sealer, spray 4 coats of passion pearl basecoat,then mix sg-150 with violet flakes and spray, then topcoat clear?Â* will this work i just dont know how long of flashes or coats are needed, i have no problem with wetsanding and reclearing for a deeper look!
    basically i want alot of violet flake over this color but want to do it correctly! Im sure it will pop and look good, epecially if i shot candy in sections
    Mar 2003
    Victoria BC
    None
    5,046
    seal with black sealer, let flash till dry to touch, usually no longer than 30 mins, basecoat, let dry until you can tack, usually like 10 mins, wait an extra 10 to be safe, spray your intercoat with flakes, wait about 30 mins(or as sg150 tds recomends) clearcoat away!!!
    the purple base should cover over black in 3 coats, do 1 coat extra after visible hiding to be safe. how many coats of flake is in your hands/effect your going for.
    ETOWN, KENTUCKY
    SOLO
    21,876
    sweet i thought about using candy over it in some sections also!
    Mar 2003
    Victoria BC
    None
    5,046
    ok so they want you to wait 60 mins before clearing sg150, and they recomend no more than 4 coats of sg150
    heres the TDS bitch!!!
    http://www.houseofkolor.co.uk/pdfs/SG150%20KARRIER.pdf
    ETOWN, KENTUCKY
    SOLO
    21,876
    hhahahah thanks bro
    Zip it cunt!
    Dec 2004
    Earthrealm
    27,104
    why black?
    hok recommends all their pbc's be shot over white base/sealer... just curious.
    ill be doing a similiar paint job soon,
    Mar 2003
    Victoria BC
    None
    5,046
    Originally posted by hot$tuff5964@Dec 27 2007, 10:01 PM~9547779
    why black?
    well then maybe white then, i'm not a big HOK user, but i always use dark sealer on darker colors, it covers better that way, but if HOK recommends it, i would go white sealer then, thanks for clearing that up
    ETOWN, KENTUCKY
    SOLO
    21,876
    Originally posted by hot$tuff5964@Dec 28 2007, 01:01 AM~9547779
    why black?
    im assuming it wont tiger stripe as easy and cover quicker..big doe did this linc with black!
    Mar 2003
    Victoria BC
    None
    5,046
    i always tint my sealer to the closest shade of that of my color, i got a gallon of white and a gallon of black, thats when i use dupont, when i use sikkens, i use colorbuild sealer, and i can tint my sealers with yellow,blue,green,red,black, and white, i can get real close to any color with that, then it covers real fast, nothing worse than pulling a car outside and you cann see thru it!!!!!
    ETOWN, KENTUCKY
    SOLO
    21,876
    so to be on the safe side i would have to mix red and blue colorbuild to acheive purple sealer correct?
    Mar 2003
    Victoria BC
    None
    5,046
    and a little white and black, i always add black, and most often a little white too when needed, but always black, because that makes it cover in 1 coat i only ever do 1 coat of sealer, want to keep the build up to a minimum.
    colorbuild is a sikkens product though, i would not use it for your HOK, i would use there sealer.
    ETOWN, KENTUCKY
    SOLO
    21,876
    Originally posted by 6Deuced@Dec 28 2007, 01:17 AM~9547951
    and a little white and black, i always add black, and most often a little white too when needed, but always black, because that makes it cover in 1 coat Â* i only ever do 1 coat of sealer, want to keep the build up to a minimum.
    do it in a datsun!!
    Jan 2003
    INDIANA
    14,495
    Originally posted by 6Deuced@Dec 28 2007, 01:03 AM~9547807
    well then maybe white then, i'm not a big HOK user, but i always use dark sealer on darker colors, it covers better that way, but if HOK recommends it, i would go white sealer then, thanks for clearing that up Â*
    thats what i do, i use black white or grey
    Feb 2003
    Louisville, KY
    12,068
    I always spray HOK over a like color sealer or solid base color. Never over white because their paint sucks. Its so transparent.
    ETOWN, KENTUCKY
    SOLO
    21,876
    preach on brother doe!
    Apr 2007
    Louisville,KY
    3,290
    I'm BUCKY BOBBY BITCHS !!!
    Leave first and never look back!!!
    Mar 2005
    NEW VISION C.C
    3,157
    HOK bases are transparent there colors are top notch
