compressor continues to run, don't shut itself off anymore???
Results 1 to 19 of 19
    Founder & Pres.
    Feb 2010
    Poconos, PA
    PedaL ScraperZ
    8,005
    Default compressor continues to run, don't shut itself off anymore???
    what could be the problem, please help
    I recently bought a 78 Caprice Landau on bags. I live in PA and it's winter here now and cold as a mofo. I took it out today 4 a quick ride, hit the switches to raise the front and back and one of the compressors stayed running for like 15 minutes after i raised it up? So than I hit the kill switch that's located by the battery to shut the compressors off. when i got back home i turned the kill switch back and the compressor started to run again and wouldnt go off again so i just flipped the kill switch again to keep t from draining the battery...
    Usually when the compressors kick on to fill up the tank they last about 5 to 10 minutes and they go off automatically but not this time.....
    What can be the problem that is keeping the compressor to run??? I'm fairly new to bags and don't know much about them. Any help or suggestions will be greatly appreciated. Thank you all in advance.
    could it be that it's soooo cold that somethings not working correctly or is it something different??? I don't want to burn the compressor out or blow anything, so I'm just keeping the kill switch off for now, until I find out what the problem is.
    Ohhh by the way there's no leaks cause I parked the car over an hour ago and left it all the way up and it's still up there.
    Here's a few picks of the car by the way.
    http://pedalscraperz.webs.com/
    http://www.youtube.com/user/PedaLScraperZ#p/a
    THE LOWER WE GET IT, THE MORE YOU SWEAT IT.
    "Hater's can only hate on me for so long, after a while they loose the title as a hater and become a hemorrhoid"
    American by birth, patriot by choice
    my feedback link: http://www.layitlow.com/forums/index...owtopic=535609
    Jan 2009
    Manhattan KS
    9,727
    Sounds like you have a bad relay to the compressor that stays running.There should be 1 relay per compressor,so track down the wires.Well there should be a relay on each compressor
    Sep 2008
    Goodyear Az
    Identity CC Az President
    5,303
    Is there a pressure switch on the tank? The switch is used to allow a certain set pressure for the tank. Mine is at 200. When the tank hits that pressure. The switch cuts of the compressors. Bagged out is also correct on the relay
    Feb 2004
    Pottstown PA
    Chosen Few C.C.
    7,126
    Give me a call homie ! I have parts in stock to fix that issue...
    Chosen Few C.C
    GoinLow Customs IS BACK.....
    Its called houndstooth........
    Dec 2008
    TEXAS
    Los Gusanos est.1979
    1,920
    relay switch or pressure switch either bad or sticking...
    HATER$
    OH, IT STAYS "OG"
    ......."Lone $tar Legend".......
    Jul 2008
    .L.I.F.E. Cen, Cal
    11,469
    do you got a gauge on the tank.If so what's is say?
    A.S r.i.p 12/17-1/11
    http://www.airassisted.com/
    Altered Altitude Customs We stock all air suspension parts. Call Or Email for a Quote!
    Ship Same Day - Tracking Number Same Day
    Toll Free Tech Support 1-866-FUK-NLOW
    Founder & Pres.
    Feb 2010
    Poconos, PA
    PedaL ScraperZ
    8,005
    Thank all of you guys for your replies I am going to check out the relay and see if thats the cause. and no gauge on the tank only gauge is in the inside of the car to let me know where I'm at psi in the bags when lfted and lowered
    Jul 2008
    .L.I.F.E. Cen, Cal
    11,469
    you need one on the tank.Everyone needs one on a tank.Makes life easier, on troubleshooting.
    Jul 2008
    .L.I.F.E. Cen, Cal
    11,469
    Quote Originally Posted by PedaLScraperZ View Post
    your relay, and pressure switch is what, turns it off and on.
    Founder & Pres.
    Feb 2010
    Poconos, PA
    PedaL ScraperZ
    8,005
    Thank you guys again, as soon as the weather breaks I'ma have it looked at and maintenenced by GOINLOW. He's going to uprade what needs upgrade-ing and adjust what needs to be tinkered with to bring it back to 100 percent.
    Thanks to all again for your assistance. I apreciate the replies and help.
    Founder & Pres.
    Feb 2010
    Poconos, PA
    PedaL ScraperZ
    8,005
    today the weather was good it hit mid 40's... went out and started the car, hit the switches and the compressors turned on and then shut off...??? now its working correctly and I didnt do anything from the other day to it. Could it have been that it was just soo cold that other day the compressor stayed running something was frozen?? now its working fine.
    Jan 2009
    Manhattan KS
    9,727
    Check the grounds
    1,039
    check valve could be stuck, do you have any idea if it was building pressure? (just throwing it out there for others who end up searching this post years from now)
    I would believe relay..in this case.
    www.AirAssisted.Com
    sales@airassisted.com
    Founder & Pres.
    Feb 2010
    Poconos, PA
    PedaL ScraperZ
    8,005
    Quote Originally Posted by baggedout81 View Post
    Check the grounds
    thanks willdo
    Quote Originally Posted by Simplicity View Post
    I would say it was when it kept running because I was able to continue to hit the switches without running out of air.
    And yes today I had it out for about 2 hours and everything worked fine had some play time and the compressors turned on and off just like they should. IDK maybe it was having a bad day the other day and didnt like how cold it was.. IDK but I'm still having my boy run a check and diagnosis of everything this weekend providing the weathers in my favor.
    1,039
    I agree, not all days are equal. I have bad days to.
    www.AirAssisted.Com
    Jun 2008
    Winnipeg, MB
    LuxuriouS C.C
    203
    check valves are just sticky bro...happens with change in weather and moisture
    C.R.E.A.M
    LUX 4 LIFE
    Oct 2009
    AWOL FAMILY lake havasu az.
    1,679
    its probably the switch but id check the air tanks too.if they are loosing air itll cause the compressors to run too.the bungs are just pressed in and known for cracking.
    Mar 2006
    Porterville California
    1,450
    check the tank for water in the lines and tank if you have water and its freezing weather it will take a while to thin out the ice.
    Sometimes shit just dosnt work out, well sometimes your devotions are much more intense or hardcore than those you spend time with. maybe my hardcore devotions are those of pure passion cause i refuse to be sub par.
    feedback
    1234
    FRESNO, CA
    blvd kings-fresno chapter
    4,724
    That's bad thing about air in cold temps. Creates moisture and water. Tanks need to be drained daily. What could have happen is pressure switch on tank going bad or had debris stuck in it to where it allow constant air flow. But Make sure drain tanks daily.
  21. Remove Advertisements
  • You may not post new threads
  • You may not post replies
