FB, FBSS, or Individual corner?
Results 1 to 20 of 34
    Baller PM'er
    Oct 2013
    MAD CITY WI
    115
    Default FB, FBSS, or Individual corner?
    Just purchased a (2) 5 gallon tank, 1/2" fast bag, 2 switch, FB setup from Erika at CCE. I upgraded to (2) Viair 480 compressors, and SS-7 bags. All for my 64 impala. I've learned that this setup has 1 line to the front bags, that splits to each bag, and the same for the rear. Seems to me that if I run into the issue of the car sagging on 1 side because of weight, I will have no way to correct it. In addition to that, running 1 line cuts the fill speed to the bags essentially in half. Actually, I can think of a whole host of issues I might have by depending on just 1 line for the front, or rear. Looking for thoughts on this, or would you go with more valves to run each bag independently. I really only need front and back, but I'm ok with going to 4 switches instead of 2. Would anybody recommend going FBSS, or would controlling each corner be a better option? Last question, is it really necessary to monitor bag pressures? I really don't want another gage mounted on my dash.
    Jul 2008
    .L.I.F.E. Cen, Cal
    12,496
    U have 8 valves or 4? I like 6 switches. Mines front, back and 4 corners
    A.S r.i.p 12/17-1/11
    http://www.airassisted.com/
    Altered Altitude Customs We stock all air suspension parts. Call Or Email for a Quote!
    Ship Same Day - Tracking Number Same Day
    Toll Free Tech Support 1-866-FUK-NLOW
    Jul 2008
    .L.I.F.E. Cen, Cal
    12,496
    I don't monitor my bag pressure, but have a gauge on tank-that's a must have. Best to have 8 valves or 6
    Baller PM'er
    Oct 2013
    MAD CITY WI
    115
    I'm only getting 4 valves with what I ordered. I think I should go with 8. I prefer 4 switches at most, but I guess six would be ok. Sounds like that would be a good idea with the way you're set up
    Jul 2008
    .L.I.F.E. Cen, Cal
    12,496
    Run 4 switches, for each corner
    Jul 2008
    .L.I.F.E. Cen, Cal
    12,496
    Quote Originally Posted by Sixtaillights View Post
    run 8 val es would be best
    Baller PM'er
    Oct 2013
    MAD CITY WI
    115
    Thanks for the input. Appreciate it.
    Jul 2008
    .L.I.F.E. Cen, Cal
    12,496
    Anytime. Best to run 8 valves. And maybe latter go e.d.c. . I wouldn't do fbss, because with 8 valves, it's like having 4 pumps. Best to do just each corner.
    Jul 2013
    Space Coast FL
    233
    I've got 4 valves to the front with 2 to the back.4 switches front,back,front corners. A sway bar would help with roll. Oh....no gauges.
    Jan 2009
    Manhattan KS
    11,581
    I run 4 switches FB each wheel in the rear.but I'm running z8 valves.I had to add a line between front bags.my shits to dam fast to try an make even
    Jan 2008
    MICHIGAN
    Nah son
    1,751
    Quote Originally Posted by baggedout81 View Post
    Yours 3 wheels?
    Baller PM'er
    Oct 2013
    MAD CITY WI
    115
    Quote Originally Posted by ATM_LAunitic View Post
    Yours 3 wheels?
    I was wondering that too
    Jan 2009
    Manhattan KS
    11,581
    I haven't really tried yet.but I have a feeling not.Not enought weight bk there to get it to tip over.im gonna put a chain bridge bk there someday.An I'm also thinking about pulling the slam 8" bags out an Tryin some tripple bellows
    Jul 2013
    Space Coast FL
    233
    Triples are for light weight. They'll bow out the side. Bags on the forward link bars should get you to tip up.
    Baller PM'er
    Oct 2013
    MAD CITY WI
    115
    Skzanoma Why did you choose to run the front corners individually vs the back?
    Baller PM'er
    Oct 2013
    MAD CITY WI
    115
    Let me answer my own question... To run the separate lines to each front bag... Might as well use your other two switches for something... Right?
    Jul 2013
    Space Coast FL
    233
    Engine weight. Didn't want to round a corner and have the air shift to one side. Plus its an S10, which has Chevy lean to drivers side front. Individual control lets me even it out.
    Jul 2008
    .L.I.F.E. Cen, Cal
    12,496
    You could wire the front to lift on two switch, and have individual dumps, if wired right, like two pumps and 4 dumps. Same with back, IF YOU WANT f.b and 4 dump cornes. Just a thought.
    Baller PM'er
    Oct 2013
    MAD CITY WI
    115
    Right now my thoughts are 4 switches controlling each individual corner. But, on the other hand, instead of hitting two switches to raise or lower the front or back, it might be nice to wire switch 1 front, and switch 2, rear. I'm still undecided what I would do with the other two switches though, whether they should control the front individually or the rear individually. If I was even to wire it that way at all
    Jul 2013
    Space Coast FL
    233
    Well, how about 1(frnt up/down) 2(rear up/down) 3(Frnt L/R down) 4(rear L/R down)
If you do not want to register, fill this field only and the name will be used as user name for your post.
