BC fab bolt in airride kits 58-65&66-68 impalas
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 46
    Warren Michigan.
    311
    Default BC fab bolt in airride kits 58-65&66-68 impalas
    Hooked up with these guys for my homies project. Shout out to jay, appreciate the help with the kit we ordered from you. Give them some love. Bcfab.com. Relentless jay is the man to talk to.
    RELENTLESS JAY
    Apr 2009
    RL, CHAPTERS, leftcoast, derbey city, music city, surf city, dirty south, thunder alley, gulf coast,
    RELENTLESS C.C. EAST TO WEST
    1,094
    Quote Originally Posted by Jahlg View Post
    much love brother
    founder of relentless carclub, I work for BC FABRICATION WWW.BCFAB.COM
    no longer w/ darlingdanika divorced her don't ask but your prob rt.
    http://www.facebook.com/?ref=home#!/...18481244900895
    RELENTLESS JAY
    Apr 2009
    1,094
    Default HEY ITS RELENTLESS JAY
    Ive been in the airride and cutom car world for years, from fbirides to americanpastimes, im @ www.bcfab.com check out some of our kits,90% of our product is made in house GIVE ME A CALL @ THE SHOP 916-944-3916 OR PM ME
    10% OFF THE WEBSITE $ FOR LAY IT LOW CUSTOMERS
    RELENTLESS JAY
    Apr 2009
    1,094
    Default Complete FBSS Airbag Suspension Kit - 58-64 Chevrolet Impala - LEVEL 2
    Retail Price: $1,599.00
    Your Savings: $300.00
    Your Price: $1,399.00
    On sale: $1,299.00
    TAKE 10% OFF
    + SHIPPING
    The '58 - '64 Chevy full-size platform has always been popular in the custom scene, and as values keep climbing you want to make sure you keep your car's value as you modify it! We've carefully assembled this kit using the best components in the industry to make sure your car retains its value while giving you a slammed stance and a comfortable ride. Designed for easy installation, our mounting brackets require minimal cutting/drilling for installation, and your car can easily be reverted to stock with little indication it was ever modified, should you desire a fully-restored look later on.
    Here's what's included:
    -Air Lift Dominator airbags- 8" of travel, 1/2" ports, 600 psi burst rate (four included)
    -8 3/8" Electric Valves- 250 psi rating, 4.5cV (FAST response!), virtually bulletproof (8 included for four corner independent control)
    -Viair 380 Chrome Compressor Dual Pack- includes two 200 psi chrome air compressors, relays, pressure switch, and more
    -5 gallon ALUMINUM air tank- perfect size for your ride, aluminum won't corrode or rust. Mounting feet on bottom for easy installation in your trunk.
    -50' roll of 3/8" DOT approved air line
    -Brass DOT approved PUSH-CONNECT air fittings- no leaks or failures with these quality parts!
    -AVS 7 switch control box- this handheld controller hides easily and fits nicely in the palm of your hand.
    -Front airbag bracket set- designed to fit your factory spring pockets and lower control arms.
    -Rear airbag bracket set- designed to fit your factory spring pockets and axle.
    -Front shock relocator bracket set- moves your shocks to the outside of your control arms.
    This LEVEL 2 system uses the same airbags and brackets from our LEVEL 1 kit, but gives you larger lines with electric valves for a faster response when you hit your switch to lift or drop. The dash-mounted control panel gets swapped out for a handheld controller that conceals easily and provides easy adjustment of each corner, as well as front, back, and all four wheels at once.
    We include complete installation guides for the installation of the airbags, as well as plumbing and wiring diagrams to make things as painless as possible. And of course, if you have questions along the way, we're always happy to help answer any questions that may come up! We've installed hundreds of air ride systems over the years, and we love hearing fr
    RELENTLESS JAY
    Apr 2009
    1,094
    Default Complete FBSS Airbag Suspension Kit - 58-64 Chevrolet Impala - LEVEL 3
    Retail Price: $1,800.00
    Your Savings: $201.00
    Your Price: $1,599.00
    TAKE 10% OFF + SHIPPING
    -AccuAir VU4 4-way Valve Manifold- Compact design, easy installation, four corner independent control
    Our LEVEL 3 kit builds upon LEVEL 2 specs, but upgrades the individual air valves for an AccuAir VU4 manifold valve for a simpler and more compact installation with less plumbing and wiring.
    We include complete installation guides for the installation of the airbags, as well as plumbing and wiring diagrams to make things as painless as possible. And of course, if you have questions along the way, we're always happy to help answer any questions that may come up! We've installed hundreds of air ride systems over the years, and we love hearing from our customers.
    RELENTLESS JAY
    Apr 2009
    1,094
    Default Complete FBSS Airbag Suspension Kit - 58-64 Chevrolet Impala - LEVEL 4
    Retail Price: $2,950.00
    Your Savings: $551.00
    Your Price: $2,599.00
    On sale: $2,399.00
    -Viair 480 Chrome Compressor Dual Pack- includes two 200 psi chrome air compressors, relays, pressure switch, and more
    -AccuAir eLevel Ride Height Control System- height sensors at each wheel let you program 3 pre-set ride heights; handheld digital controller allows you to adjust your height at the touch of a button!
    Our LEVEL 4 kit represents the way we'd build your ride if it was ours! In this case, Viair 480C air compressors and an AccuAir valve manifold with their eLevel automatic ride control, with everything else from the LEVEL 3 system carried over. Sure, you can still spend more money on chrome air tanks and such, but the equipment in this package is the highest quality for your ride!
    RELENTLESS JAY
    Apr 2009
    1,094
    Warren Michigan.
    311
    Do work son! Have I told you that I love that ride
    RELENTLESS JAY
    Apr 2009
    1,094
    Default Complete FBSS Airbag Suspension Kit - 1965 - 1970 Chevrolet Impala - LEVEL 2
    Part Number BK511A
    Retail Price: $1,600.00
    Your Savings: $251.00
    Your Price: $1,349.00
    The '65-'70 Chevy Impala has been gaining popularity over the past several years, and you want to be sure to keep its value as you modify it! We've carefully assembled this kit using the best components in the industry to make sure your car retains its value while giving you a slammed stance and a comfortable ride. Designed for easy installation, our mounting brackets require minimal cutting/drilling for installation, and your car can easily be reverted to stock with little indication it was ever modified, should you desire a fully-restored look later on.
    RELENTLESS JAY
    Apr 2009
    1,094
    Default The '65-'70 Chevy Impala has been gaining popularity over the past several years, and
    Complete FBSS Airbag Suspension Kit - 1965 - 1970 Chevrolet Impala - LEVEL 3
    Part Number BK511B
    TAKE 10% OFF THE SALE PRICE
    + SHIPPING
    RELENTLESS JAY
    Apr 2009
    1,094
    Default Complete FBSS Airbag Suspension Kit - 1965 - 1970 Chevrolet Impala - LEVEL 4
    Part Number BK511C
    Retail Price: $3,000.00
    Your Savings: $521.00
    Your Price: $2,479.00
    TAKE 10% THE SALE PRICE
    + SHIPPING
    RELENTLESS JAY
    Apr 2009
    1,094
    RELENTLESS JAY
    Apr 2009
    1,094
    Default Complete FBSS Airbag Suspension Kit - 64-69 Lincoln Continental - LEVEL 2
    Part Number BK578A
    Retail Price: $2,500.00
    Your Price: $2,349.00
    On sale: $2,249.00
    take 10% the sale price
    + shipping
    If you've been wanting to lay your Continental on the ground, but were scared away by the custom fabrication or the price to have it done, your wait has come to an end!
    This kit is designed for ease of installation and a smooth ride. The front and rear suspension components bolt into many of the factory mounting points, and require only minimal welding to secure a few of the brackets to the axle and lower control arms.
    -Rear 4 link system- designed to replace your leaf springs to locate your axle on your frame, and incorporates the air spring mounts.
    We include complete installation guides for the installation of the airbags, as well as plumbing and wiring diagrams to make things as painless as possible. Feel free to ask any questions about putting this kit in and we'll be happy to assist! We love hearing from our customers and seeing their projects come together.
    RELENTLESS JAY
    Apr 2009
    1,094
    Default Complete FBSS Airbag Suspension Kit - 64-69 Lincoln Continental - LEVEL 3
    Part Number BK578B
    Retail Price: $2,650.00
    Your Price: $2,449.00
    TAKE 10% OFF THE SALE PRICE + SHIPPING
    RELENTLESS JAY
    Apr 2009
    1,094
    Default Complete FBSS Airbag Suspension Kit - 64-69 Lincoln Continental - LEVEL 4
    Part Number BK578C
    Retail Price: $3,800.00
    Your Savings: $501.00
    Your Price: $3,499.00
    On sale: $3,299.00
    + SHIPPING
    RELENTLESS JAY
    Apr 2009
    1,094
    Warren Michigan.
    311
    What are the options on a macpherson strut car?
    Riding low and drivin slow. That's my motto
    Warren Michigan.
    311
    Ttt
    RELENTLESS JAY
    Apr 2009
    1,094
    Default ILL BE AT GOODGUYS CAR SHOW THIS WEEKEND COME BY THE BOOTH ABND SAY HI
    NO MORE BS
    Sep 2008
    SIN CITY
    CRUISING CLASSICS
    9,415
    Fuck, should have bought from you! Next kit for sure!
    '60 PARKWOOD - 6 PASS
    '61 IMPALA 4 DOOR HT - FOR SALE $4900
    '61 IMPALA RAG
If you do not want to register, fill this field only and the name will be used as user name for your post.
