Need help air bags sometimes wont lift
Results 1 to 5 of 5
    Feb 2015
    18
    Default Need help air bags sometimes wont lift
    Whats up fellas newbie here having some trouble with my elco with air bags in front..driver side air bag lifts great all the time but the other one sometimes i hit the switch and doesnt lift doesnt make a clicking noise or anything..when it does make a clicking noise it does lift no problem..i just put a new hose but i beleive it wasnt tightened right because it does leak and drops really fast..could that be the problem?thanks for any responses i get
    Sent from AutoGuide.com Free App
    Mar 2010
    1,014
    Check to make sure all your wires are tight and making contact. Test by moving wires to different switches
    Worst. info. ever.
    a mexican named mark aguirre invented the first lowrider you hillbilly piece of shit how GTFO
    Feb 2015
    18
    Thanks..and my compressor also wont turn off as soon as i connect the battery it turns on and this all happened when i moved some wires around could it all be related?and exactly which wires should i be looking at?thanks again
    Warren Michigan.
    399
    Need to figure out what wires you moved around. If comp wont shut off it most likely pressure switch. If it's leaking it won't stay inflated, check all your wiring first. Check the basic things first, power and ground. Then make sure valves are wired correctly
    Riding low and drivin slow. That's my motto
    Feb 2015
    18
    Quote Originally Posted by Jahlg View Post
    Thanks bro and well like i said im a newbie so where would the valves be located?car is slammed all they way down so im having a hard time getting under
  7. Remove Advertisements
