newbie
Results 1 to 6 of 6
Thread: newbie
    Jun 2016
    2
    Default newbie
    Couple air suspension questions
    OK so I am new to this whole air suspension deal but I just bought a truck that already had it installed. The questions I have are probably pretty simple for most of you. When the truck is lifted up and I hit a switch to drop it, it drops extremely quick. I was curious if there is a way to make this drop a little slower? I don't know if you can just change to a smaller air fitting in the bag or what? Also I have what I would guess to be a 5 gallon tank and two compressors but they run an extremely long time. So long that I have actually left them on for 20-25 minutes and they never shut off. There is not a pressure gauge on the tank and the guy told me he elected to spend more money toward the bags than the compressors. So I guess my question is should I have a gauge put on the tank? What size compressor should I be running for this tank? How long should this take to fill up?
    Any information is helpful also I do not know the brand of system that was put on the truck. Thanks
    Chris
    Nov 2012
    San Antonio TX
    54
    You can buy slowdowns for the valves that release the air from the bags. Yes get a gauge on tank to make sure your not overfilling which can lead your tank to exploding. Many different brands of compressors out there I have Viair 480 twin pack and it takes about 12-14 min to fill up my 8 gallon tank. If you look up Viair it will show you fill up times for each model.
    758
    Check your pressure switch as well. Comps shouldn't be running that long. You can buy slowdowns or get creative and make some. I have 2-480 viair and it's filling 5gal tank, 5/6 minutes fill time.
    Jul 2016
    Fuck u password reset cc
    111
    Quote Originally Posted by hatws6 View Post
    Chris
    Jul 2014
    The Drapes CC
    27
    I got 2 480's and an 5 Gal Tank from 0+12 Bar ( 220PSI) it takes 6.30 Min
    I also have an Gauge on the Watertrap that shows the Pressure of the Tank and an Miniblowoutvalve that work at 14 Bar
    And for a slower down take slowdowns like this
    http://www.avsontheweb.com/mufflers-slow-downs/
    If you can't Fix it with an Hammer, you got an Electric Problem !
    Jul 2013
    Space Coast FL
    281
    Comps taking that long could be fighting a stuck check valve. Also, you can get 1/4 turn valves from home depot to put on your exhaust ports. Then you can tune the speed of drop.
  8. Remove Advertisements
