Airline near exhaust manifold - help
Results 1 to 9 of 9
    Mar 2010
    6
    Default Airline near exhaust manifold - help
    What to do about being too close to manifold.
    Hello,
    I joined here a long time ago and the project I was asking about did not work out, but now I'm in the middle of a project (1959 Buick) and I find myself needing some guidance. My air lines in the engine compartment will get quite close to my exhaust manifolds. I don't want my plastic airlines to melt so I've been trying to fit some copper lines to get me out of the engine compartment. Problem is I've been having trouble getting a good seal and I just don't trust them in the long run for fear of cracking or the flange loosening up with vibration or heating/cooling cycles. Does anyone have suggestions on how I should handle this? Steal lines? (didn't want to use steel for fear of rust) Hydrolic lines? Are there any that could take the heat? Any other ideas?
    686
    Ok, assuming you are trying to use dot plastic line? Not good idea to have anywhere near heat, or have a tow rig handy. I've run copper lines on my impala since day 1. You can also do stainless lines. How are you trying to connect the lines? I used ptc for my copper. Just got to make sure it's cut straight. Can you post pics of where your trying to run your lines? Hydro hoses would work as well but not by heat. Got to be some way of routing lInes away from heat source. Need to see pics thiugh
    Toronto
    Loser
    1,323
    you can also cover the line in a heat (fire resistant) sleeve to protect it, or wrap the manifold, or run the line inside the frame.
    www.AirAssisted.Com
    sales@airassisted.com
    We stock all air suspension parts. Call Or Email for a Quote!
    Ship Same Day - Tracking Number Same Day
    Toll Free Tech Support 1-866-FUK-NLOW
    Mar 2010
    6
    These pictures are terrible but now that I'm looking at them I might be able to use regular plastic line and build a small heat shield near the exhaust manifold. That may work with the hydrolics hose as well.
    686
    Are you using flared fittings? Hard to tell with the pics. I had trouble with flares. I went to compression fittings and ptc, ptc are the easiest to use. Just make sure you cut it with a tube cutter nice and straight without squeezing the line to much. Then ream it out and get shavings out. Your ride is bad ass. Where you live? Didn't list on profile. Are you running 3/8 or 1/2" lines?
    Mar 2010
    6
    Thanks for the compliment on the car! I hope to be driving her again by spring. I had flaired line in there but yesterday I tore it out and just went with hydrolic hose. Will tie into the 3/8 plastic line under the car. Making some heat shields for the exhaust manifolds. Oh, I'm in Eau Claire WI.
    686
    Damn. That sucks to tear it all out. I wanted to do that a few times during my install. I'm going to switch it to braided stainless all the way. Already have the lines. Just need to tear it all apart and run them.
    Mar 2010
    6
    Here's what it looks like now. I feel a lot better about this than that copper I had.
    And I gave up on the heat shields and went with this heat protection loom stuff.
    686
    Should work just fine.
  11. Remove Advertisements
