School me on shocks
Results 1 to 7 of 7
    Aug 2016
    41
    Default School me on shocks
    1978 shocks for airride
    I know nothing about shocks and airride, i am looking at either QA1 or ride tech shocks. I want the car to sit about .5-1" off the ground. I plan on mounting SS7 bags in the front and SS8 bags in the rear. As far as shocks go i have no idea if i need adjustable or not, also which line of QA1 do i need they have so many different types. I don't know what extended length and collapsed length i need. Any info would be very helpful, i am going to do my very first airride install on a 1978 Monte Carlo. FBSS
    Banned
    Majestics
    14,772
    A shock absorber on a car is designed to do one thing and one thing only.
    It is designed to prevent a car from bouncing.
    Aug 2016
    41
    so how do i pick the length of the shock when i lower the car to the ground? or is it just vehicle specific?
    Chandler Arizona
    USO Phoenix
    670
    Do the full air ride, find your ride height and get shocks that match that.
    1 love 2 palm trees 3 letters 4 life
    1997 Lincoln Town Car
    Hit me up for your Air Suspension needs
    Edgar@airslamit.com #AirSlamit
    www.AirSlamit.com
    Aug 2016
    41
    So install everything and then order the shocks?
    Chandler Arizona
    USO Phoenix
    670
    yes shocks should be last
    www.AirSlamit.com
    New york
    2,252
    Are you going to be making bag and shock brackets or buying them. In the front you will most likely be doing a custom shock bracket as opposed to a bolt on so you need to have a rough idea of what you are going to use to set it up properly. There are usually space limitations with that type of suspension, but it all depends on the tire and wheel combination.
    I have a few shocks that I keep on hand that i know will fit most applications and i build my brackets from there. If you wait till the end you may run into issues limiting drop and lift. In your case since you are thinking to go with an ART shock, then I would start with one that they use on their full size kits so you know its valved for that type of vehicle. You can measure its extended and compressed lengths and use that to position your brackets properly.
    IG: @thegreek96
  9. Remove Advertisements
