Tanks going empty
Results 1 to 20 of 30
    Sep 2003
    Royal Image, WA
    1,383
    Default Tanks going empty
    So I need to know why both of my tanks are going empty just over night from 180PSI to zero. I'm using two 5 gallons tanks with 2 brand new 480C Viair compressors.
    I been checking all my fittings and can't find a leak. My rear also drops over night if I leave them filled up.
    Royal Image C.C.
    Bellingham Chapter
    Chandler Arizona
    USO Phoenix
    670
    What type of valve do you have?
    1 love 2 palm trees 3 letters 4 life
    1997 Lincoln Town Car
    Hit me up for your Air Suspension needs
    Edgar@airslamit.com #AirSlamit
    www.AirSlamit.com
    Sep 2003
    Royal Image, WA
    1,383
    Honestly I couldn't tell you. All I know is that I have 8. 4 at front and 4 on the rear.
    Chandler Arizona
    USO Phoenix
    670
    Check the check valves at the end of the leader hose on the compressors those seem to go bad pretty easy, check if the compressor head is leaking
    www.AirSlamit.com
    Sep 2003
    Royal Image, WA
    1,383
    How do I check the check valves? I heard you can't tight them too much. I wonder If I should loose them a bit or if its too late once they are over tighten. The compressors are brand new. About a month old.
    775
    How are you checking for leaks? Have to be pretty significant to lose that much overnight.
    Sep 2003
    Royal Image, WA
    1,383
    Soapy water on a spray bottle.
    Toronto
    Loser
    1,323
    remove the air inlet filter, cover with your thumb and spray, if you see bubles, your check valve is stuck in the open postition.
    www.AirAssisted.Com
    sales@airassisted.com
    We stock all air suspension parts. Call Or Email for a Quote!
    Ship Same Day - Tracking Number Same Day
    Toll Free Tech Support 1-866-FUK-NLOW
    Oct 2015
    Detroit
    98
    Do you have water separators? I've had nothing but problems with them leaking after a year of so at 200psi.
    I've had a problem with fittings leaking (swivel and non swivel, parker and plastic)
    I seem to have better luck with steel or stainless adapters into steel on the tanks than brass.
    But really just need to tape or use sealant and crank it down tight since its a tapered pipe usually.
    But like stated above get some snoop or soapy water and check all connections.
    Aug 2016
    3
    Did you get this fixed? It seems like these guys have you on the right direction to resolve your issue.
    FWIW, I have found that the dollar store kids bubbles make 1000% more concentrated bubbles so it becomes obvious when any air escapes compared to using soapy water. I would lose about 1 psi a day in my rear ds bag and couldnt find anything with soapy water. As soon as I used kids bubbles in the same places it was crazy how many bubbles showed up right at the leak. 1/4 turn with the wrench and 18 months later, no leaks.
    775
    Great bit of advice. Thanks
    Sep 2003
    Royal Image, WA
    1,383
    Thank you everyone for the input. This weekend I will try the balloons concept and spraying the fittings with the kids stuff.
    Sep 2003
    Royal Image, WA
    1,383
    Ok guys I still can't find any leaks. I sprayed the fittings and I can't find any bubbles. The rear still goes down just not over night. It takes about a day in a half to go all the way down. And that's both rear bags. Here's a drawing I put together real quick. Maybe you guys can tell me if something looks wrong. By the way, I'm also getting some water on both water traps. I know it's normal but a bit more I'm used to seeing.
    The Peoples Choice
    Majestics
    14,837
    Quote Originally Posted by Royal50 View Post
    Did You spray the tanks themselves ,mounting area, welds etc.
    spray every inch of the hose or hoses it sells it could be leaking there
    Sep 2003
    Royal Image, WA
    1,383
    Will continue to do that. So will a bad check valve cause both my rear bags to empty out? Anything hooked up wrong on my diagram?
    775
    Looks like your lines are teed front and rear. That's why they both go down not just one. Is this a daily driver? How many valves it doesn't show the dumps on the diagram. Is the tank going empty or just the bags?
    Sep 2003
    Royal Image, WA
    1,383
    This is not a daily. I have 8 valves. My tank has been going emptied but for some reason since last night it's still holding. So I guess just my bags in the rear are going empty.
    Sep 2003
    Royal Image, WA
    1,383
    Well I found my leak. At least I hope it was only that one. It was the fitting connected to the tank to the water trap. It was leaking from the water trap side. I just dropped the see through part of the trap and sinned it until it was tight. Then I used a wrench to make sure it was tight. Well update in a couple of days to see if it holds.
    775
    Cool. Glad you found it.
    Sep 2003
    Royal Image, WA
    1,383
    Well I spoke too soon. My leak is slower and it's not from any fittings on either tanks, or compressors. But my tanks are loosing air overnight and so are my rear bags.
