new to air ride couple questions, nitrogen - Page 2
Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
  1. #21
    727
    If the bag was leaking it most likely wouldn't air up at all. Odds are fittings are leaking there. Yes you'll have to pull the front bag to get to fittings. Which means disassembly of front suspension, easiest way to get it out. Should have all thread coming up thru the front shock hole, can unbolt the upper ball joint and break free spindle unbolt the all thread and feed the cup and bag out of spring pocket. May need to unbolt lower bag plate as well. Been a few since I've pulled mine out for service. Going to in the spring g to run new lines.
  3. #22
    Feb 2002
    805x702
    5,067
    im taking the front apart this week to seal up leaks but im confused with how it leaks, the front pass side always sinks down, if I lower the front the back dosnt sink, if I leave it all up either both front or both pass side sinks (either or not both)but front driver and back pass take turns staying up or sinking never both at the same time and each wheel is on a different line. also first time I hit the front switch pass side dosnt go up til after the drivers side is up until I have them both up then lower then they both go up together. not sure why it dose this will seal up front and see if back pass side leaks or not and post results
  4. #23
    727
    You could have leaky valves. I'm convinced that's what my issues are. If I pull in the garage and air it out, it will slowly raise the rears. Takes a few days. If I leave aired up it will drop the passenger rear.
  5. Remove Advertisements
