ok heres the new build up topic, more put together this is gonna be a long build becasuse im a picky motherfucker on a budget, so bare with me All hating is welcome!
i saved it from a feild of death the car wasnt in too bad of shape :biggrin:
immediatly pulled the clip, dash,inerior, engine & tranny out and pulled off the vinyl top to see if there was any rust
welded up the harness hole since im running a painless harness later on!
now time for the fun part, i removed the wiper assembly since this car wont see rain and shaved the gutter sytem as well, i used some thick steel for the wall for reinforcement, oh i also capped the hood stopper bracket on the drivers side since it would have been left open
a mag for motivation! :biggrin:
welded
time for some mudwork, i used big does advice and used all- metal filler later on around the edges!
I had to extend the piller so i used 1/8 inch steel and cut as an L-shape, so the fleet windows would have something to screw to, the L peices were spot welded in but weld thru- primed before hand to avoid rust inbetween the metals
also the gutter rail had to be removed over the frame also welded and fiberglassed back in to the inner quarter glass jamb structure jamb
needs more blocking but starting to look good!
i also went ahead and scuffed the inside roof section the used a high build primer to block any moisture
rotessorie got back from powdercoat, so we installed the brace kit provided by classic customs on here to be safe, it had to be made longer for my mile long door jambs. body is on
Originally posted by LUXURIOU$LAC@Apr 13 2008, 04:35 PM~10406004 i know, i forgot to tell jay to post it in project rides, im sure someone will hook it up! :biggrin:
Originally posted by LuxuriouSMontreaL@Apr 13 2008, 04:41 PM~10406028 yeah you were probably thinking of those wide whites while making this thread... :uh: :biggrin:
Related Threads
LayItLow.com Lowrider Forums
17.7M posts
191.1K members
Since 2002
LayItLow forum is an online community for true Lowriders. Come in and discuss hydraulics, air ride tech tips and all the information you need for dropping your lowrider.
