| radicalplastic09 |
Nov 2 2009, 09:37 PM
| | Post
#1
roundestmound Posts: 1,072 Joined: Jun 2006 From: MI Car Club: the bike in progress |
so i looked up the specifications and the sensitivity says 87.6 db so does that mean i need to have my amp at 87.6 db for best quality or performance or is that the max amount it will handle?and the impedance says 4 ohm dual coil so does that mean i need a 4 ohm amp as well? as you can tell im quite new to the technical audio game.thanks in advance for any input
-------------------- roll roll roll your joint lick it at the end take a puff thats enough pass it to a friend
PICS OR IT DIDN'T HAPPEN! "i will admit i've had a vibrating bullet in my ass and liked it"- quoted from hearse(male) on monday may 21, 2007 |
| Advertisement | |
| MLBTLB |
Nov 3 2009, 07:07 AM
| | Post
#2
GRINDIN Posts: 1,336 Joined: Feb 2008 From: ST. LOUIS Car Club: LUXURIOUS |
so i looked up the specifications and the sensitivity says 87.6 db so does that mean i need to have my amp at 87.6 db for best quality or performance or is that the max amount it will handle?and the impedance says 4 ohm dual coil so does that mean i need a 4 ohm amp as well? as you can tell im quite new to the technical audio game.thanks in advance for any input IM ALMOST POSITIVE JL W0 DIDNT MAKE A DUAL VOICE COIL SUB? -------------------- is this 21 questions?write a fuccen book! ~~~~Livin Life LuxuriouS~~~~
San Jose ~ Central Valley ~ Chicago ~ Montreal ~ Utah ~ Indianapolis ~ Michigan ~ Kentucky ~ New England ~ British Columbia ~ Toronto ~ ST. LOUIS ~Miami ~ Nor Cal ~ Winnipeg ~France |
| baggedout81 |
Nov 3 2009, 08:15 AM
| | Post
#3
Baller Poster Posts: 2,305 Joined: Jan 2009 From: Manhattan K.S. |
IM ALMOST POSITIVE JL W0 DIDNT MAKE A DUAL VOICE COIL SUB? -------------------- http://www.layitlow.com/forums/index.php?showtopic=509831
RE bag install in the cutlass http://www.layitlow.com/forums/index.php?showtopic=490251 EDC install http://www.layitlow.com/forums/index.php?showtopic=498541 Upper bag cup's in a g-body |
| radicalplastic09 |
Nov 3 2009, 08:18 AM
| | Post
#4
IM ALMOST POSITIVE JL W0 DIDNT MAKE A DUAL VOICE COIL SUB? Manufacturer: JL Audio Product MPN MPN 12W04 Key Features Car Speaker Type What is "Car Speaker Type"? Component Elements 1-Way Car Speaker Function What is "Car Speaker Function"? Subwoofer Size 12" Nominal Power Handling 125 Watt RMS Powered Non-Powered Technical Features Peak Power Handling 300 Watt Sensitivity 87.6 dB Impedance 4 ohm (Dual Coil)[SIZE=7] Components Surround Material Foam Mounting Enclosure Non-Enclosed Top Mounting Depth 6 In. Mounting Diameter / Length 11 In. Warranty Warranty 90 Days -------------------- roll roll roll your joint lick it at the end take a puff thats enough pass it to a friend
| MLBTLB |
Nov 3 2009, 08:42 AM
| | Post
#5
Manufacturer: JL Audio Product MPN MPN 12W04 Key Features Car Speaker Type What is "Car Speaker Type"? Component Elements 1-Way Car Speaker Function What is "Car Speaker Function"? Subwoofer Size 12" Nominal Power Handling 125 Watt RMS Powered Non-Powered Technical Features Peak Power Handling 300 Watt Sensitivity 87.6 dB Impedance 4 ohm (Dual Coil)[SIZE=7] Components Surround Material Foam Mounting Enclosure Non-Enclosed Top Mounting Depth 6 In. Mounting Diameter / Length 11 In. Warranty Warranty 90 Days -------------------- is this 21 questions?write a fuccen book! ~~~~Livin Life LuxuriouS~~~~
| radicalplastic09 |
Nov 3 2009, 03:05 PM
| | Post
#6
so i looked up the specifications and the sensitivity says 87.6 db so does that mean i need to have my amp at 87.6 db for best quality or performance or is that the max amount it will handle?and the impedance says 4 ohm dual coil so does that mean i need a 4 ohm amp as well? as you can tell im quite new to the technical audio game.thanks in advance for any input ? -------------------- roll roll roll your joint lick it at the end take a puff thats enough pass it to a friend
| 82fleetwood |
Nov 4 2009, 01:07 AM
| | Post
#7
Enthusiast Poster Posts: 112 Joined: Jan 2009 |
87.6 db means the input sensitivity, if you get a amp at 100 watts put it to the jl at 87.6 db it wont play as loud to a speaker lets say 92.2db. if your looking for speakers that you will be putting to a stock radio or to a radio and not a amp look 4 a speaker that has a high db sensitivity. it will play louder. it dont take much to make them sound good. 4 ohm lets you know how to wire the sub and what amp to put 2 it... if it is a dual 4 ohm you can get a 2 or 8 ohm load. now a 500 watt amp at 4 ohms now turns to a 250 watt amp at 8 ohms and a 750 to 1000 watt amp at 2 ohms. you can go down to 1 ohm but you got to make sure your amp will handle it. if you got any more questions just pm me. im pretty good but not a master. i will help you with anything you need
-------------------- http://www.layitlow.com/forums/index.php?showtopic=500419
[B][FONT=Geneva][SIZE=14]WHO BANG'N AUTO SOUNDS HIT ME UP FOR ALL YOUR STEREO NEEDS......... |
| radicalplastic09 |
Nov 6 2009, 01:26 PM
| | Post
#8
I FRIED MY FUCKIN AMP!
| 82fleetwood |
Nov 9 2009, 11:25 PM
| | Post
#9
i would say yes.... but the fuse should of blew out b4 the amp acn burn. unless you used a big ass fuse..
| radicalplastic09 |
Nov 14 2009, 03:42 PM
| | Post
#10
i would say yes.... but the fuse should of blew out b4 the amp acn burn. unless you used a big ass fuse.. nope dont think so it was a 25 and the wire hit the casing of the amp and it sparked up like a christmas tree -------------------- roll roll roll your joint lick it at the end take a puff thats enough pass it to a friend
| Lo-Fi Version | Time is now: Nov 21, 2009 - 02:16 AM | |
| Home | Forums | Tech | Rides | Bikes | Girls | Store | Info | Outline | Help | Privacy | Advertising |
