| Schimel750 |
Jan 27 2004, 11:23 PM
| | Post
#1
Enthusiast Poster Posts: 241 Joined: Sep 2003 From: Chattanooga TN |
How exactly do i plumb a 1 pump 4 dump setup so to get individual control from it for 2 wheels. I guess when activated, the 3rd or 4th dumps close off whichever side to cause pressure, which fills the other cylinder??
or maybe someone has some detailed info on a 4 dump manifold i can get my hands on SOMEONE HELP!! -------------------- A man with a gun, and a good idea, is always dangerous
If your juice ain't leak'n, it's outta oil! Why every hood nigga feed off evil,..answer my question, before the bullet leaves this desert eagle |
| Advertisement | |
| BOUNCIN89MERC2LOW97LHS |
Jan 28 2004, 06:33 AM
| | Post
#2
Baller Poster Posts: 2,097 Joined: Apr 2003 From: Dela-square |
OK, draw this up as you read it so it's easier to understand.
Tee out of the pump as you would normally into the first two dumps. Plug the "Normally Open" (the other side) port of both dumps. Pipe out of the "Dump" ports of both of those dumps into the "Normally Open" ports on the second pair of dumps. Pipe out of the other "Normally Open" ports to your cylinders. Pipe the "Dump" ports of those two back to your pumps as usual. Keep in mind, you now need 6-prong switches for individual control, and 12-prong for front or back. So a pancake switch is out of the question unless you can find a 24-prong switch. They're out there, but I'd say forget about it. The reason for so many prongs is because each corner now has to activate the first dump (as well as the pump) in order to raise. You'll get it as you draw it up. I thik I need to draw something up 'cause a lot of people ask about this. -------------------- SIGNATURE & CAR UNDER CONSTRUCTION... '00 Deville DTS
'97 Chrysler LHS - 2 pump, 8 dump, 48-volt, 6"front/8"rear 4 CCE accumulators, 17x9 KO's ***** "...Hip-Hop is my inalieanable right..." KRS-One / 2003 ***** "...Dee dee dee dah dee dee dee dee dee dah dee day, All you sucka MC's won't you please come out to play..." KRS-One / 1986 ***** "Rap is something you do, Hip-Hop is something you live." KRS-One |
Jan 28 2004, 06:49 AM
| | Post
#3
I just threw this together. It's just one pair but you'll get it. Hope it helps.
| Team SMB FAB-LAB |
Jan 28 2004, 07:22 AM
| | Post
#4
TEAM FAB-LAB Posts: 3,616 Joined: Apr 2002 From: Louisville, KY (PRP) |
Just bye another pump!
-------------------- SDNC LAWN & LANDSCAPINGLouisville KY
| purpl7duece |
Jan 28 2004, 11:50 AM
| | Post
#5
Addict Poster Posts: 3,170 Joined: Jun 2002 From: T-Town, AZ 623 |
What moves can you do with 1 pump 4 dumps?
-------------------- 2009 LIL AWARD WINNER
Need Chrome & Aluminum Engine Parts?? My Chrome Parts My Feedback I got beer so expensive that you've never even heard of it. Corona drinking bitches couldn't handle 1/3 of it. |
Jan 28 2004, 01:41 PM
| | Post
#6
Well, it sounds like he's only hooking it up to 2 corners, so just individual up and down in the front or back only. -------------------- SIGNATURE & CAR UNDER CONSTRUCTION... '00 Deville DTS
| Schimel750 |
Jan 28 2004, 09:49 PM
| | Post
#7
ok check it, i've got a whole 4 pump setup,...but i'm a smart ass and like to do things normally most people wouldn't. i like to challenge myself. yeah i could just carry over the 3 pump from my Blazer (which is a 4x4, in comes the smartass) but that would be too easy.Plus it's a body dropped Bronco II, not built to hop or stunt or nothing. just think the added abilty to dogleg and shit would be a crowd pleaser. and i'm also trying to keep it clean and simple yea know, less is more!
i think that will answer all the "why even bother" questions or remarks any of you might have -------------------- A man with a gun, and a good idea, is always dangerous
| Schimel750 |
Jan 28 2004, 10:14 PM
| | Post
#8
sweet man!! thanks man...i was thinking, just out of curiousity, so that i don't get a wild hair up my ass and try it...what would happen if you wired the pump and the 1st dump to the same prong? it should still activate them at the same time, with 24 volts right?
what i'm asking is, what would happen if the pump and 1st dump we wired together, would that cause you to lose anything? like trying to run a pancake on a 6 prong, you lose your ability to dump corners ya know -------------------- A man with a gun, and a good idea, is always dangerous
Jan 29 2004, 05:56 AM
| | Post
#9
Well if you wired the first dump to the same prong as the pump, it would open every time you activate the pump. Basically you'll end up with a 2-dump system like everyone else. ...UNLESS you add diodes to each "PUMP" wire on every switch to keep the power from crossing over to the other side (DUMP). It's possible but I was just trying to give you the easy way out. I did that for a minute in '91 but finding diodes that can handle the amperage wasn't easy back then. I can get them at All Electronics now, but I run something different from regular switches now anyway. -------------------- SIGNATURE & CAR UNDER CONSTRUCTION... '00 Deville DTS
| Schimel750 |
Jan 29 2004, 10:57 AM
| | Post
#10
what do you run other then normal switches? you runnin push buttons or somthing??
| Lo-Fi Version | Time is now: Jul 30, 2010 - 03:59 PM | |
| Home | Forums | Tech | Rides | Bikes | Girls | Store | Info | Outline | Help | Privacy | Advertising |
