4 compressor setup help
Results 1 to 4 of 4
    71
    Default 4 compressor setup help
    Can someone tell me what's the best way to wire up 4 viair 444 compressors. Will an 80 amp solenoid work or do I have to add an additional battery dedicated to the comps?
    INFO STALKER
    Apr 2011
    20
    The 80a or “stinger” relay will be fine. You can wire both comps the that relay. Then use your pressure switch to controls the relay. Done.
    INFO STALKER
    Apr 2011
    20
    The 80a or “stinger” relay will be fine. You can wire both comps the that relay. Then use your pressure switch to control the relay. Done.
    INFO STALKER
    Apr 2011
    20
    Not only did I double post I realized I miss read your question too. I would run 2ga to a distribution block then run two 4ga runs to two 80A relays. As far as the p/s it should be able to wire it to control both relays.
  6. Remove Advertisements
