Golden Age 1964 Impala
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 20 of 79
    Mar 2007
    North Carolina
    all about the old school
    179
    This post is to show the status of my 64 Impala and the years and work it's taken to get it to where it's at today. I couldn't have done any of it without the help of some great friends. It's not perfect or complete by any means but it's a cruiser and that's what i have it for. Someday soon maybe i'll get it painted the color i've always wanted... Silver Blue with a white top. Ok, on to the pictures!
    i kick my volume way past ten...
    www.manifestworldwide.com. For all your Old School Flavor!
    Golden Age 1964 Impala Build
    Mar 2007
    North Carolina
    179
    a few pics of how it looked when i bought it:
    Mar 2007
    North Carolina
    179
    more pics of how it looked when i bought it:
    Mar 2007
    North Carolina
    179
    a pic snapped at the cinco de mayo show a year or two before i bought it:
    Mar 2007
    North Carolina
    179
    first thing i had to do was put some 13's on her for a better stance. also got rid of the single exhaust and put on dual exhaust with classic 18 inch glasspacks to make some noise. here's a pic of her all cleaned up ready to show. not sure who put this trim on or why, but it needs to go.
    Mar 2007
    North Carolina
    179
    second thing to get straight was the leaking motor and slipping powerglide. pulled both out and sold to a local dragracer.
    Mar 2007
    North Carolina
    179
    Since i bought this car almost 4 years ago, here's the list of what's been done. I'm sure i'm forgetting a few small things along the way but here's the major stuff:
    • Complete front suspension rebuild with new ball joints/ tie rods & sleeves/ front shocks/ upper & lower control arm bushings/ sway bar bushings & drag link bushings and sleeves.
    • All new power steering box/ hoses/ slave cylinder replaced/ installed new pressure valve/ rebuilt oe unit installed.
    • Installed power booster & master cylinder/ front disc brakes/ all new steel brake lines/ new flex hoses front and rear/ replaced wheel cylinder in rear.
    • Removed gas tank, cleaned, painted/ installed new sending unit.
    • New 100 amp alternator installed.
    • Rebuilt 283 motor with all new 8 connecting rods/ steel crankshaft/ .030 pistons/ new rings/ new oil pump/ water pump/ fuel pump/ steel fuel line and filter/ cam and lifter kit (327/350 hp)/ valve spring, retainers and locks/ bronze guides and seals/ brass freeze plugs/ chrome dip stick/ chrome thermostat housing/ wood air cleaner spacer (1/2 inch)/ chrome pcv valve/ oil filter adpater/ balancer bolt/ cam brg set/ timing tab/ 1 piece oil pan gasket/ new 500 cfm carb plus other things i'm sure but you get the idea.
    • New chrome valve covers and air intake.
    • Removed original powerglide and replaced with 200R 4 speed transmission with overdrive. Much better on the highway and gas! New electrical connections/ low-kar pressure cable/ dipstick etc.
    • Rear end rebuilt. All bearings and seals/ ring gear & pinion (326 ratio).
    • Installed 2 piece telescoping driveshaft with heavy duty carrier bearing.
    • Removed original single exhaust and replaced with dual exhuast 18" glasspacks.
    • New BF Goodrich tires with 13x7 100 spoke wire wheels.
    • Removed bad plastic trim and installed correct chrome 64 impala trim and rockers.
    • Installed tissued holder under dash with cd player/ ipod connect inside. 2 3 1/2" speakers in dash/ 2 5 1/4" speakers in front kick panels/ 2 6x9" speakers in back deck/ 2 10" rockford fosgate speakers in trunk with 2 amps for everything.
    • All new custom airride setup installed. 4 slam re 7 bags/ 1/2" lines all around/ 2 10 gallon tanks in trunk/ 2 viair 380 compressors in trunk/ 8 1/2" smc valves in trunk/ 2 1/2" water traps in trunk/ 2 ball valves in trunk/ 1 200 psi gauge/ 1 square d adjustable pressure switch/ 4 mufflers/ all brass and copper fittings throughout/ 5 switches on custom made switchplate.
    Mar 2007
    North Carolina
    179
    pics of the motor all shined up. hated to get it dirty!
    Mar 2007
    North Carolina
    179
    Finally got that awful plastic trim off and put on the correct 64 impala trim with rockers to complete the look. That trim bothered me for years. Couldn't wait to get it right. Totally changed the look of the car 100%.
    Mar 2007
    North Carolina
    179
    Next i had to get a plaque for the back window. I'm not in any clubs so i figured i'd make one to represent my company, Manifest. My high school friend Jason has his own fabricating/ metal shop and worked up this amazing one of a kind plaque off a drawing i gave him. It turned out amazing and turns heads wherever i go. the chrome on this thing is like nothing you've ever seen.
    Thank's again Jason and if you need your own plaque made, check him out at http://epicmetalworks.net/
    KICK ROCKS
    Nov 2005
    where we roll 13x7s
    North Texas
    14,345
    Originally posted by golden age@Dec 8 2010, 02:34 PM~19274177
    Finally got that awful plastic trim off and put on the correct 64 impala trim with rockers to complete the look.* That trim bothered me for years.* Couldn't wait to get it right.* Totally changed the look of the car 100%.
    yea it did
    6DEUCE BUILDERS CLUB
    "YOU CAN HAVE THE BADDEST CAR OUT THERE...BUT IT DOESNT MATTER IF YOU HAVE A SHITTY ATTITUDE. YOU CAN ALWAYS CHANGE A CAR..BUT NEVER CHANGE THE HEART OF A PERSON."Abel Perez
    MAJESTICS NORTH TEXAS...THA COAST 2 COAST CHAPTER...
    62 HT---"Backyard Bully"
    91 Mustang 5.0---"Menace to Society"
    02 HD Electra Glide---"Monsta"
    Mar 2007
    North Carolina
    179
    Next up was doing the airride setup. I debated with doing this or saving up for a paint job with body work. Well the paint and body will be a costly and timely project and i'd rather roll it how it is and enjoy it. So after almost 3 years or so of owning this car and doing everything except the paint and body, i decided to go ahead and do the airride. I know alot of people don't like air or think it has to be juice if it's on an impala. I say it's your car, you paid for it so you should do whatever you want. But i will say, this airride setup has changed some minds of hydro fans. Clean and fast and very quite!
    Mar 2007
    North Carolina
    179
    For some reason i thought this airride install would take a weekend, maybe 2 solid days. Maybe not. It took myself and 3 good friends 4 solid days from sunup to sundown to complete this. I never imagined it would take this long but with only one of us doing this before, it took us a bit longer. And about 8 trips to home depot and lowes for more and more fittings. I'm sure they thought we were building some kind of pipe bomb or moonshine still.
    And i have to give a huge shoutout to Frank from http://kustomairsuspensions.com/ he was a huge help and was always there to answer any question we had. Hit him up for any airirde needs!
    Below is the setup i put together to do Front/Back-Side to Side-All up and pankcake:
    Mar 2007
    North Carolina
    179
    More shots of the 64 with airride:
    Mar 2007
    North Carolina
    179
    Debut of the impala on air at the local show. These old guys aren't fans of the airride or maybe it's the small wheels? Heard "are you mexican now" a couple of times. Gotta love the south!
    Mar 2007
    North Carolina
    179
    Tell me this isn't a magazine worthy shot
    Mar 2007
    North Carolina
    179
    I was 14 or so when i saw my first 63 impala lowrider and was hooked right from the start. Well it took me almost 19 years to have mine and be able to "hit the switch". There is nothing like it, that's for sure!
    Mar 2007
    North Carolina
    179
    pic from photographer extraordinaire jesse williams:
    Mar 2005
    Killeen,Texas (Ft. Hood) by way of Marshall, TX
    1,038
    Great Job bro. Congrats the car looks sweet. I'm feeling that plaque too.
    62 Impala HT REDD Foxx
    96 Impala SS "DarkneSS"
    "I been regulating since Cragars was the Daytons "
    "Praises Go Up!!!, Blessings Come Down!!!"
    Sep 2010
    El Monte
    1,144
    Well look at that. You build a righteous 64 and you get compliments
    ♫6♫2♫♫S♫S♫♫I♫M♫P♫A♫L♫A♫ ♫6♫2♫♫S♫S♫♫I♫M♫P♫A♫L♫A♫ ♫6♫2♫♫S♫S♫♫I♫M♫P♫A♫L♫A♫
