1 - 11 of 11 Posts
well my 52 chevy i don't use reducers i drop each corner individually startind in the back but when i drop the front i do crack the concrete with the frame that was the force i use 1/8 reducers sometimes but still it donna dump fast diff set ups depending on distanse from bag
wow none of that really made sence what i was trying to say is depending on how your setup is it could change how you dump but i guess 3/8 reducersto a shotr leighnth of line
or use smaller valves but need to consider if they will handle the pressure to dump cuz your lift valve can over power your dump valve and it will lock up
do it in a datsun!!
Originally posted by shorty 2low@Aug 28 2003, 08:17 PM
ok will the dump be fast? Dan says he has 1/4 reducers on his 1/2 dump...will this 3/8 dump faster? does this sound good?
Includes:
Air Tank 8-Port
4-Fill Valves
4-Dump Valves
1-110on/145off Pressure Switch & Tee
1-Drain Valve
All Fittings For Complete Installation for $565
i was thinking the same thing,no sense in paying for a 1/2" valve if your gonig to put a 1/4 reducer on it :)
Includes:
Air Tank 8-Port
4-Fill Valves
4-Dump Valves
1-Drain Valve
Yes, 3/8 will dump faster! Have Fun!!!!!!!!!! :biggrin: :biggrin:
Originally posted by impala_631+Aug 29 2003, 02:58 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (impala_631 @ Aug 29 2003, 02:58 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--shorty 2low@Aug 28 2003, 08:17 PM
Includes:
Air Tank 8-Port
4-Fill Valves
4-Dump Valves
1-Drain Valve
i was thinking the same thing,no sense in paying for a 1/2" valve if your gonig to put a 1/4 reducer on it :)[/b][/quote]
exactly. just make sure they are rated for the pressure you plan to run.
I bought 1/2" drops, and have the frons reduced to 1/8" and the backs to 1/4"..
I'm quicker on the switches now though, I may make the fronts 1/4 and the backs 3/8 now..
Straight 1/2" all the way around!I love the way 1/2" dumps on the rear!! It is awesome!My front end could be a little slower being that I have to tap the front down!Hehe
Originally posted by shorty 2low@Aug 29 2003, 07:35 PM
...humm i think i would be happier with 1/2 all the way around....i need to put together a set up that will hold plenty of PSI....any one know
Just go with a reputable company on the valves such as Parker,Herion,or SMC.
Go for it! Just make sure you get what you want the first time around.I am saying this because I have been there.I spent $2500.00 3 years ago on Air-Ride Technoligies think'n it was going to be fast!Little did I know then.Sold all of that for like $600 and some new stereo equipment.I still took a loss. :angry:
Remember if it is going to be to FAST you can always slow it down!If you go to slow you'll never get it to be FAST!
;) :cool:
1/2 valves are a good all round valve. Lift fast drop fast, just get good quality valves and you shouldnt have any problems. I'm using multiple sizes of valves cause i just happen to have all my old valves so why not use them. I'm using everything from 3/8-1/2-3/4 valves 3/4" valves work great for dumping the back
1 - 11 of 11 Posts
