1 - 3 of 3 Posts
I've got an 83 4dr cutty sitting here and i have and 81 malibu wagon for my daily. i want to keep driving the wagon for the winter, so i'm thinking i could scrap the cutty's body. Wrap the frame get the suspension ready over winter and drop the wagon onto it in the spring. The two frames are identical, both being G-bodies correct? Also will the cutty front clip match up if i swapped it on? And finally would an olds 350 fit into this mutt of a vehicle(enough room for it). Any insite or further ideas are much apreciated.
You can make anything fit. My buddy had a RANGER with a 350 in it. He had to do a lot of work but, he made it happen. I'm not sure as far as the frames go but, if you want to fab. some things then I'm sure you could do it.
they have 2 different frames.....the clips may fit...might have to change the doors with it.......the engine should fit no problem....just gotta change your motor mounts...
1 - 3 of 3 Posts
