1 - 13 of 13 Posts
is this ok to do? ive heard it mentioned once before , just want to see what everyone thinks? thanks
i know a guy right now who has 4 pumps and 48 volts to each pump and only runs one noid to each pump soo...i guess its a personal thing
Yeah definitely...
Trefive is only running one solenoid on his 1-5 24 volts and I'm running one per pump on my 2-4 24 volts.
Phoenix Chapter President
1 solenoid per 2 batteries,thats the norm,but I know a few folks running 3 to 4 batteries off of 1 solenoid and no problems,but I wouldnt suggest it....
Originally posted by milkweed@Jan 15 2009, 05:29 PM~12710391
it will work just fine,  the reason for multiple noids is safety  if one sticks on you the 2nd will still break the circuit.
thank everyone for your help
but im not likely to have one stick if im using low volts?
i have a quick disconnect also
low voltage is 1 of a few causes to make a solenoid stick
your solonoids are more likely to stick open if you are low on charge. Not if you run only 2 batteries. If you have 2 batteries you would normally have 24V, but if your batteries are low on charge you will only see 20V or so, depending.
i usualy run the rear of hoppers on 24v with 1 noid
1 - 13 of 13 Posts
