1 - 12 of 12 Posts
The 12's should get louder. More cone area. As long as youre comparing subs of the same type (e.g. you cant put a Pyramid 12 up against a Digital Designs 12). But lets say you have a kicker comp vr 12 and a kicker comp vr 10. Powered off of the same amp, the 12 should be louder.
Originally posted by Foompla+Sep 6 2003, 04:47 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Foompla @ Sep 6 2003, 04:47 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--deftonekorn1002@Sep 6 2003, 05:21 PM
2"
4"*
its not the size. its how you use it.[/b][/quote]
You really might not be able to tell the difference between subs in a store (big open room). The difference will be in the vehicle.
Bigger subs can go lower in tone (i.e. 15 lower than 10). but have a loss in puch/tighness.
Smaller subs can hit tighter tones more accuratly (i.e. 10 tighter than 15).
The above is just a genral idea, and every sub is different. So no bitching from the nit-pickers please. :biggrin:
the larger subs diplace more air and produces more spl. But the subs may not play as clearly or as tight when they get larger. But if you are using a good brand sub and not something from best buy there should not be very much of a change in sound quality with different sizes
really depends on brands and make ,, some 10's sound hella betta than some 12's and some 12's sound better than some 10's ,,.. listen to more an go with what ya ears want to listen to ..
Originally posted by 83Cutlass+Sep 7 2003, 04:20 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (83Cutlass @ Sep 7 2003, 04:20 PM)</td></tr><tr><td id='QUOTE'>
2"
4"*
The above is just a genral idea, and every sub is different. So no bitching from the nit-pickers please. :biggrin:[/b][/quote]
*bitch*
2"
4"*
*bitch*
1 - 12 of 12 Posts
