I was wondering if 13 inch og's would fit on a 88 caddy fleetwood RWD? I was told teh caliper in teh front wont fit.....is this true??
what size of wire would u run?
Guess my car isnt a lowrider, no I just want my car safe when I am doing 80 on the freeway, get 13s if you dont plan on puttin hydraulics on it.Originally posted by Joost....@Jul 29 2005, 10:30 AM
i think 13s is the way to go, youre building a lowrider :biggrin:
[snapback]3503883[/snapback]
Freeway, I have to take it if I want to go to anyshows.Originally posted by Joost....@Jul 29 2005, 12:13 PM
why doin 80 with it? If you wanna drive fast you need a sportscar, its a lowrider :biggrin:
[snapback]3504753[/snapback]
I do, why have a car you cant do 80 on the freeway with, I drive the freeway all the time and I cant stand gettin past I like my car fully functional, dont get me wrong I would roll 13s an everything except towncars and cads, I had 13s on my car for a week I hated it.Originally posted by mJr-Regals4lyfe@Jul 29 2005, 12:24 PM
go on the freeway but you dont have to do 80
[snapback]3504822[/snapback]
:thumbsup:Originally posted by 509Rider@Jul 29 2005, 12:32 PM
[snapback]3504860[/snapback]
why you say not to run spacers?Originally posted by DA FROGG@Jul 28 2005, 09:45 PM
do not run spacers! just grind the front calipers down....and you should run 13.7 all the way around..
[snapback]3501277[/snapback]
[snapback]3505061[/snapback]
About how much do u gotta grind down on the calipersOriginally posted by enough_talkin@Aug 1 2005, 12:50 AM~3518076
grind the calipers down and put the 13's on it....those lacs dont look right with 14's IMO
what i did is grind the calipers and added a 1/4'' spacer between the adapter and the rotor, i lube the threads and use a torque wrench to tight down the lug nuts to 70 ft/lbs. I don't know if this is true or not but, has anyone else heard that you don't have to grind off as much with china wheels?Originally posted by TYTE95@Jul 4 2008, 12:34 AM~11011013
i had to grind a pretty good amount around the pins and some off the top/front and add spacers. not feeling to safe about it though so i ordered a new set of calipers in case i feel like going back to 14's. i love my 13" d's but i may have to try out some 14" z's.
