13X7 chinas on a 82 Sedan Deville?
540 Views 9 Replies 4 Participants Last post by  Kandy Drippa
Will they work in the back? or will i have to grind down the inner wheel well?
1 - 10 of 10 Posts
Nah, its an 82.
are you lowring it or putting hydralics on it? then yeah i would grind a lil so the tires wont rub when you drop the rear
Originally posted by 81 FLEETWOOD@Sep 21 2006, 01:33 AM~6215778
its a rwd right?
Yeah.
And im not sure if im gonna juice it. If so i'll probably just put 13x6 in the back.
THEY DONT MAKE 13X6 HOMEBOY, ONLY IN 14S THEY DO, JUST GO WITH 13s AND CUT A LIL FUCK IT :biggrin:
Damn, you're right.
Im not even sure if im getting the car. I hope so though, its cheap. :)
13's will fit you can even lower the factory ride height by removing the air from the shocks and it will not rub unless you put 3 ppl in hte car that weight over 200lbs
they make 13x5.5
1 - 10 of 10 Posts
