1 - 13 of 13 Posts
Do you have to narrow the rear on a coupe deville to fit 13x7 or 14x7 reverse offset on it?
It's an 83 coupe so it's the rwd one. I thought I remember someone saying something about it and wanted to check. Thanks in advance.
I GOT 14/7 N MINE AND THEY DO RUB ,I WAS TOLD TO RUN 6 INCH WIDE ON THE BACK ON 13S OR 14S .
i was told 13s dont rub
i know from experience that 14.7s do rub and 14.6s dont
THEY ONLY RUB ON THE EAST COAST. WE RUN 13x7's ON LINCS. AND CADDY'S ALL DAY EVERY DAY ON THE WEST COAST.
409
:roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao:
Now that I'm done clownin' 13x7's might rub with O.G. D's or Z's. You'll need to trim a little off the wheel well in back. Up front you know you have to grind the shit out of the caliper and use a spacer on the adapter, I know I did. Now, with chinas for what ever the reason they fit better in the back without any trimming of the wheel well. Up front, little or sometimes no grinding of the caliper is needed. Maybe a very thin spacer up front.
I had 14x7s on my 84 and they didn't rub. But if they do all you have to do is grind down the inner fender a little. No problem. The front will need a spacer and a little caliper grinding. Again no problem.
go with the 14's no grinding, i didnt even trim anythign in the back with the 14x7 and 175/70 tires, i only have a slight rub when completly dumped out........
:thumbsdown:
I got 14 X 7's on my 84' and they dont rub, hell i even got fender skirts on my caddy n the rims dont rub at all. didnt have to grind or shave off inner fenders.....
LAC RIDAH
My players are 13's. only needed 1/4" spacers up front no grinding of caliper needed, and rear barely rubs on left side when taking a corner too hard or fast.
1 - 13 of 13 Posts
