he knows his shit. Imo, i wouldnt go with tha 14x6, 14x7 comb becouse your tires will show wear in tha front faster. So if u get tha same exact size all around u can rotate to achive even tread wear.Originally posted by mean3wheel_lean@Aug 23 2005, 12:41 AM~3671344
true, but sometimes the place where the rubbing occurs is eliminated by going with the smaller height, you have to remember that the tire is on an inward angle towards the tread, so in certain instances, if the wheel is shorter height wise you eliminate the rubbing
and if that doesnt work you can go with 13x5.5 in the back
or do the 14x7, 14x6 combo.......
no doubtOriginally posted by 75caprice@Aug 23 2005, 11:17 AM~3676138
its better to just go with daytons.
