Originally posted by CuttieBuddie@Aug 9 2005, 08:40 AM~3569475
well i already found your problem...
1.75cuft. isnt enough for that sub-woofer... the MINIMUM size ported box recommended by kicker for the 05L7 15" is 3.0 cuft.... being that its a prefab box, i will garauntee that the box your using isnt tuned correctly to match that sub...
using peel&seal or dynamat xtreme (sound deadening material) in the doors of your van can eliminate most of your rattling which will allow better bass response and all around output....if you want to be a sound junky, you can remove the panels and carpet, and outline the entire cabin of your van in peel &seal or dyn xtreme....
everything i wrote in this post is why there is no such thing as SQ in your van....
what should you do?
go to home depot or lowes and buy some MDF(Medium Density Fiber) 1" wood, a box of 2.5" - 3" drywall screws, and a couple of tubes of liquid nails...go to google.com and look for a blueprint of a slot vented box sized and tuned to the L7's specs, and build yourself an enclosure...
-qs
