1 - 20 of 29 Posts
I wanna put 16's in the rear.going to do a power three on both sides
need pic's and what parts need to to be modified.I hear adjustable upper and slip yoke but also relocating the uppers and extinding the upper arms 2''
please need help thanks :cool:
well first off you need to change the rear put coil over and then drop your top mounts 5" and xtend the top trailing arms 1 inch and you should be fine
i got a freind with a regal he had 16in in the rear and he broke out his back window 3 times before he changed over to 14 in the only porlem was the cylinders hitting the deck deck and shattering the back window so you might have to cut out the back deck out some so the cylinders wont hit it
putting bridge in rear to hold up any three wheel
yeah going coil over with showtimes 14'' comp. and power balls
drop your trailing arm mounts 2" and extend the trailing arms 1.5" and you can lock it... pinion angle will be somewhat ok just prior to lockup, anymore and you need slip yoke
Originally posted by gonzalo94541@Sep 12 2005, 11:11 AM~3798648
anybody know anything?
if i were u id coil over that homie :cool: throw on some power balls :biggrin:
Originally posted by gonzalo94541@Sep 12 2005, 01:38 PM~3799213
want to make it a hopper :cool:
You gonna get started on some re-enforcing?
Originally posted by gonzalo94541@Sep 18 2005, 05:01 PM~3839269
just bought some 14's with deep rev. cups and springs.I need to know if any modifying needed?thanks :cool:
well do powerballs and just gotta weld your powerball to your rear axle just make sure iys in the dead center of where your spring is and you sould be fine, coil over is the way to go i have coil over in the front and back on my limo :cool:
were u like hot boxing that thing?
u need a slip yoke or u might fuck something up and u might need to extend ur trailing arms proably not tho and just mabey brake lines
1 - 20 of 29 Posts
