1 - 20 of 24 Posts
alright well i called around i cant get any 175's in whitewalls around here even checked walmart...
now whats the difference between the two? my car aint gunna be lowered for a little bit...
will the 185's look ugly? compared to the 175's like is there much of a difference?
also if my caddy isnt lowered am i gunna have a problem with 14/7?
its a 87 rwd... stock rims are 15/6 with 225 15's...
alright i got
cooper se2'!
175/75/14 :p
found a place in the city cheapest too mounted and balanced they didnt think they could get the tires cause they arent wide enough but i told em that its what everyones has and its been done lots before...
anyways they had to use this blowgun thing to inflate the tires... cause they wherent wide enough...
but they looks SWEET!
THANKS KEITH! YOU THE BOMB!
Originally posted by 67impala@Nov 15 2003, 05:08 PM
alright i got
cooper se2'!
175/75/14 :p
Good choice, the copper trensetter SE's are good tires and are nice and skinny in 175/75/14
yea man everyone wanted like 400+ for 4 tires mounted and balanced...
i got my coopers for 339...
question i looked at all my rims and they all have wieghts on em except one of em...
did they forget to balance one wheel?
[/quote]
usually what occurs when they mt/bal is they spin the wheel first, and mark where it's high. then, mount the tire and spin the tire and wheel, and mark where the tire is high. Then they rotate the tire on the rim to counterbalance the weight of the wheel. So, if the weight is the same as the wheel, then no weights are needed. You may want to request this the next time you buy tires, and they should use your best two rims on the front to give you the best ride. :biggrin: :thumbsup:
1 - 20 of 24 Posts
