1 - 9 of 9 Posts
1952 Plymouth Cambridge.....this car is about 95% original....the only things that were replaced are the starter solenoid, the headliner,the paint, the shocks,and the front seat cover....the driver side flat glass is cracked but easily replace.. the brakes work ... ......it has a flathead 6 cylinder with 29,000 original miles and a 3 speed on the column......the trunk still has the original mat from the factory.....the body is basically straight as can be.....there is NO ROT OR RUST on this entire car....the floors are all solid and all the light and gauges work.......the horn etc. everything works and the motor runs really quiet.......the paint shines well
SOLID DRIVER! will not find one in this kind of shape this cheap $4000 drive it home
NO BONDO,all steel
only 29k orig miles, always garaged.
selling the shop, needs to go $4k
1 - 9 of 9 Posts
