1 - 2 of 2 Posts
1955 International, Rat Rod, Custom, Low Rider, Hot Rod, Air Bagged, Custom Pickup!!!
Front and back lift on two switches. The front is fast and will jump off the ground about 4" at 250 psi. which is amazing because the front is a heavy big block. The back is air shocks that the fitting where drilled from 1/8" to 1/4 in" for a little faster lift. It has a nine gallon stainless steel air tank with four 450 psi valves.
http://cgi.ebay.com/ebaymotors/Internation...570407751QQrdZ1
7-day listing,
Ends Aug-28-05 21:51:55 PDT
Start time:
Aug-21-05 21:51:55 PDT
1 - 2 of 2 Posts
