501 - 520 of 524 Posts
I bought a Right Stuff drum to disc conversion kit for the front and back of my 4-door 64 impala and my 13s will not spin on the front without scraping. The back are fine. However, I purchased some 15s instead because the instructions stated that 14s were the minimum they supported and now my rims sit way too far out. When I turn it scrapes the edge of the fender. Anyone have any ideas on how I can fix this without having to buy more rims or new spindles? I just need about 1/2 an inch so that it doesn't scrape the fender when I turn but if I can get an inch that would be much better because I want to cut the coil about 2" to lower the front a bit.
You bought the wrong kit. You need to purchase the scarebird kit.
Moderator
This entire topic says exactly what you need in detail.
Just purchased this front disk brake kit for my 64 Impala with 13" China wire wheels. Anyone else use this kit on their Impala and did you have any problems?
Moderator
That'll work as long as you don't have adjustable suspension due to the brackets pushing the wheels out about 5/8" on each side.
Scarebird is the way to go......
Looks like the Brake Kit from speedway is going back. I'll purchase the scarebird brackets instead:thumbsup:
OLD SCHOOL OG
was wondering what's the difference in using the s10 spindle compared to the caprice small spindle?
I have a set of s10 completes laying around but want info before I tear it apart and mess something up.
WILL the s10 work?????????
any info would be great. tying to get this handled and installed this week!!!
******CAN NOT USE FACTORY SPINDLES. I HAD BROKE THEM IN A COLISSION LAST YEAR*****
Yes, S10 will work
OLD SCHOOL OG
Has any one actually used the s10 spindles to do the
Brake conversion?
Also what's the difference between the s10 and caprice?
I can't use my factory spindle for conversion,
Hence why I'm swapping for s10 or caprice!
Any help would be great!
Brake conversion?
Caprice spindles are atleast an inche taller w/an 11" rotor. Which equals taller lock up and more brake surface.
OLD SCHOOL OG
But that means my tires will lean way more than the 1.5" extension
I already have now and eat up my tires right?
The Peoples Choice
Less you're doing full custom car I don't see the need to swap out to disc breaks. Properly adjusted drum brakes work just perfect.
Moderator
For the rear I absolutely agree. Properly adjusted drum brakes get the job done. For the front though, discs stop better, shorter, don't require adjustment, and easier to inspect for wear. The swap made sense to me with having worn shoes and making the switch to power booster/dual master.
** 58-64 Rag Impalas **
I's agree wif MacMosca! :inout:
The Peoples Choice
To each their own I suppose. I guess there are certain Lowrider dues that do 80 and 90 miles an hour and need to "stop quicker" or dudes with heavy trunks.
OLD SCHOOL OG
did the front and rear disk conversion with caprice spindles,
turned out ok.
s10 spindles will NOT work, arm lays on spindle and will not turn,
OLD SCHOOL OG
