1 - 5 of 5 Posts
anyone know what connection on the wiper motor gets what connected to it..
mine doesnt work, I'm trying to figure out why...
or just point me in the direction of a good websit with the info...
thanks
oh, I'll post a pic if you need me to...
thanks
You know if its a single speed or dual speed? Mine's a dual and it works I can look at it if you want. Check how many wires you got... Are they hooked up and just dont work? you check them for power? motor might be shot and it gets power...
Originally posted by bigdanmcintosh@Jul 30 2003, 05:19 AM
ya, I checked for power on all 5 wires and had none..
it has 2 connectors, a 3 pin and a 2 pin...
I believe it's a 2 speed...
I went ahead and took a pic and some readings real quick...
#1 gets power when the car is on, its wired into the ignition switch somehow.
#2 runs into the connector with the 3 wires, in the middle to #4.
#3 not sure...
#4 connects to #2
#5 was on when motor was running high not sure about low...
These could be incorrect, I'm just thinking from memory...
I only had a few minutes to check things out but your main concern is you dont have voltage when the IGN is on, i had power just with IGN on and no switch on.
Maybe #3 is used for when the pushbutton for the sprayer is engaged, not sure.
1 - 5 of 5 Posts
