URK BOOGIE
Anybody ever put an air bag kit on a 66 buick shylark. If it makes a differnce it an airbagit kit
URK BOOGIE
I figured out the valves. These are the brackets i got to figure out.
URK BOOGIE
<IMG id=vbattach_0 class=previewthumb alt="" src="http://www.layitlow.com/forums/attachment.php?attachmentid=0&stc=1" attachmentid="0">I figured out the valves. These are the brackets i got to figure out.<IMG style="BORDER-BOTTOM: medium none; BORDER-LEFT: medium none; MARGIN: 1px; BORDER-TOP: medium none; BORDER-RIGHT: medium none" id=vbattach_0 class=previewthumb alt="" src="http://www.layitlow.com/forums/attachment.php?attachmentid=0&stc=1" attachmentid="0">
I Dig Chix Wit Glasses!!!
Auto part
1. These go together, they for a lower mounting bracket pair.
2. These are one set (upper and lower).
3. This is for the front, and is the upper mounting brackets.
now to find out which goes where is a little fit here fit there. I know for a fact that #3. is for the front and bolt in place (looks like some S10 uppers), the lower is probably #1, Not sure. #2. is for the rear, the one with the most holes in it is the top and the one with the two is the lower.
URK BOOGIE
i got the set up in the problem now is the solinoids are not working properly. They hit every now and then. The dumps click almost every time the fills click seldomly. The fills click sometimes and the bag still dont fill. I think they may be sticking. how do i fix this. One more thing the wire off the solnoid is bigger than the wire that they give you for the switches
View attachment 345039 1. These go together, they for a lower mounting bracket pair. 2. These are one set (upper and lower). 3. This is for the front, and is the upper mounting brackets. now to find out which goes where is a little fit here fit there. I know for a fact that #3. is for the front and bolt in place (looks like some S10 uppers), the lower is probably #1, Not sure. #2. is for the rear, the one with the most holes in it is the top and the one with the two is the lower.
