1 - 5 of 5 Posts
I wanna put front disc brakes on the cutty is there any way I can convert them with parts from the salvage yard thanks
sounds like a question for a forum that caters to that gen of Cutlass
you can always look for 68-72 gm A bodies with factory disc brake setups at the junk yard. You need to make sure you pull the entire spindle setup and brake line brackets as its not just a rotor and caliper conversion.
go to the CUTLASS topic for help homie!! im sure someone there can give you a hand on how to do this...
1 - 5 of 5 Posts
