Both have thier original boxes.
79-original instructions, neatly made into convertible. Body and interior are in primer. No other assembly. Used to be a built kit that I took apart carefully. Windsheild frame has a repair in it, will be easy to sand down. One taillight is broken, but you can replace it with a peice of clear plastic tinted red. Has decals
80-photocopied instructions original instructions, has t-top roof (no glass came for the t-tops though). Includes a separate peice to make a vinyl half top. Body and interior come primed, only flaw is a hole that used to have a hood ornament in the cowl, I filled it, needs to be sanded smoother. No rear glass, but it's all straight, so I'll put in a peice of clear plastic to make some. Also a formerly built kit. Has decals
My bad, engine blocks are glued together, nicely
I replaced most of the parts with unpainted originals still on the tree from my kits, since I'm using something else to detail it out, so basically you're getting a mint kit with a clean bodies. No minibikes included.
Good rare kits for lowriders-40 bux each or 70 for both, shipped. They gotta go, I need the green.
K. Diaz
pics below
K. Diaz
pics below
