1 - 2 of 2 Posts
Has anyone here swapped at narrower rear end onto a 1980 Deville or fleetwood? I've been told a caprice/impala rear end is compatible. Can anyone help?
6.0L engine 368 with th4100 tranny.
[email protected]
80's caprice/impala is a direct swap, same with 92+ caprice/caddy (and you get disc brakes), but none of these are narrower than what you have. if you want a stock narrower rear end you can use a g-body rear end but I believe you have to change or modify the upper trailing arm brackets.
1 - 2 of 2 Posts
