Up for sale is my 1982 Cadillac Coupe Deville which has the following:
Car is Gold(was repainted a few years ago very nice still),Has Tan leather interior(front lower seats are torn but it has matching covers over seats.).
Has a 1980 Chevrolet 350 small block 4 bolt main.Engine came out of a Camaro that had about 70k miles on it.The car currently has no a/c(Have a compressor-remaned-used for a month on my monte carlo) and all mounting hardware and brackets but needs the lines to the compressor)everything needed is there in the car less stated.
Also has a turbo 350 trans,shifts very smoothly engine also runs fantastic doesn't skip a beat,smoke or leak.Body over all is a 7 of 10(has small rust spots starting and is missing the front left lower filler panel.)also needs the side rubber molding unless you plan on painting it or it doesn't bother you.(painter taped it off or applied the side right after paint.I removed it and there is 2-lines on sides of car.)When I purchased the car a few months ago the odometer had 2 miles on it(car just rolled over 100k),it now has 958 miles on it.I drive it daily.It gets good gas mileage believe it or not.
Also heres a list of other things I have done:
BRAND NEW:
-Gas tank.
-Fuel Sending unit(and sock filter).
-Battery.
-Dual 40 series delta flow 2 1/2" exhaust from manifolds back with turn downs before axles.
-new/reman. 2bbl carb.
-Electric external fuel pump and pre-filter.
-3" cone air filer.
-chrome valve cover breather and grommet.
BRAND NEW 24" Status Marshall Rims with Toyo 255/30r24 Tires(Cost about $2500-From BLVD Customs)
No lift no cutting of the body,car rides just like stock because it is all stock suspension wheels dont rub but will if you hit a large bump going fast enough i suppose. . other then that its perfect.
Recent maintenance:
-NGK Spark plugs.
-Spark plug wires.
-Distributor Cap.
-Distributor rotor button.
-Valve Cover Gaskets.
-20w50 Oil.
-Oil filter.
All done this past week.
$3700 obo or will consider the right trade. . But prefer cash. . thanks!!
***************OR **********
STEREO:
Kenwood kenwood xxv-o1d 25th anniversary Cd/MP3 player
Kenwood kgc-7043 Digital Eq in dash(no hooked up to stereo as of yet.)
Memphis 15-PRC46 4x6" speakers up front
** I do have available for $4500 total cost of the car and the following:
2-Memphis 6x9",2-Memphis 5.25"s and 2-Horns in a fiberglass enclosure in rear deck covered in Tan Suede.
Front Fiberglass Center console-Covered in Tan suede(also 2-cup holders) with a total of 4-Memphis 6.5"s and 2-Power acoustic super tweeters
All Mids and highs and tweeters powered by 2-4channel JDL I-Max 880 amps.
2-MDX Subs with custom blow-thru sealed box threw arm rest and MDX 3000 mom block class D amp.(with all new wiring and 2-Group 31 deep cycle batteries.
Auto page alarm with LCD screen pager auto start auto locks and auto roll down windows and trunk release options.
None of the stereo mention is in the car its still all brand new in boxes at my shop and none of the enclosures have been fabricated yet but for the price mentioned above it will all be installed and enclosures built.
BRAND NEW:
-Gas tank.
-Battery.
-3" cone air filer.
Recent maintenance:
-NGK Spark plugs.
-Spark plug wires.
-Distributor Cap.
-20w50 Oil.
-Oil filter.
STEREO:
